How to secure my wireless connection? - Computers & Internet
    Problem Solver:
  • 12 Answers
Open IE, go to your router using 192.168.1.1 and select Wireless security for the router you are using. Use WEP or WAP with 64 bit security. Use the same key on your desktop to connect to this secure connection.
Posted on Apr 19, 2008
Cant connect to the internet..
Hi, What error do you get when connecting to the internet?
Anyways, Probably the Wireless connection your trying to connect to has a Network Security enabled on it.
Gaming consoles cant' access that type of Encryption, reason I do not know why but to be able to get wireless connection using your Nintendo DS you will need to disable the Wireless Network Security of your Wireless Router to be able to get Wireless Access using your Nintendo DS.
I also had issues with mine before and found out that disabling the Network Security will let me get Internet Access on my portable console.
Just Disable the Network Security this will allow you to get Internet Access on your Nintendo, for the Security of your Wireless you can get the MAC Address of each wireless device you have and input those MAC Addresses into the Router Settings to get Security and not allow other poeplt to gain access on your Wireless Internet.
I hope this Helps.
Have a nice day,
mvincentc
Jul 27, 2011 | Nintendo DS Lite Console
MY PS3 WILL NOT CONNECT TO MY WIRELESS ROUTER DLINK 615, everythink else does.
This will connect for the following reasons:
1. Check if the wireless security key is correct.
2. The wireless security key is at times case sensitive.
3. Try and connect to your own wireless network
4. Finally, check with other wireless devices at your place, if they are connecting.
5. If the security is high, lower down the wireless security type to 64-bit WEP
For verifying all this, contact your router vendor.
Thanks for asking.
Arvind S Iyer
Oct 17, 2010 | Sony Playstation 3 (PS3) Console
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
Jun 18, 2010 | Linksys WRT160N Wireless Router
Dell TrueMobile 1150 won't connect to secured wireless acct.
well! some wireless adapter`s are not capable of connecting to higher security so that`s why for that it`s recommended you use WEP security instead of WPA.
Jul 01, 2009 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Unable to identify the users connected to my wireless internet
1st of all change your wireless access password then re enter the wifi security key with 128 bit encryption.
by the way how Manny PC u using with your wireless internet connection ?
May 19, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Modem Router not connecting to desktop
The wireless security on your router might be enabled.
1. In the address bar of your Internet browser, type "192.168.2.1". Then press the "Enter" key.
2. It will prompt for a password to access the Router’s Web-Based Advanced User Interface. By default the password is blank.
3. Go to Security, then Wireless.
- Check the wireless security settings, this should match the settings on your wireless computer.
4. On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Jan 14, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
D-Link Router
first of all are you talking about a secure wireless connection. if you aren't, then what it means is using an encryption key to secure your wireless connection. any computer connecting to your router can connect wirelessly and use your connection to do whatever they want unless you secure it. let me know a little more details and i will help you get it all set right.
Sep 19, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
