Question about Samsung LN-T4042H 40 in. LCD HDTV
The picture on our Samsung LN-T4042T is flickering like crazy. Could it be the color wheel? How much would it cost to replace (when a technician does it)? Or can we do it ourselves?
  • 11,361 Answers
Your TV is an LCD flat panel TV, it does not use color wheel like the DLP TV.
You may have problem with either the power supply or the backlight inverter board, you need to check them out.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 11, 2010
My TV has a severe flicker/jitter in the bottom left quadrant of the screen. How do I fix it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 27, 2017 | Samsung LN-T5271F 52 in. LCD Television
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
My samsung dlp lost it's color and the picture is flickering and breaking up sound is fine It's also making a louder humming sound than usual. what is the problem
It sounds like the color wheel has failed and will need to be replaced. Color wheel will cost around $175.00-$200.00 plus 1-1.5 hours labor. You can call 1-800-samsung for the nearest service center.
Aug 06, 2010 | Samsung DLP HL-P5663W 56" TV
My screen color looks like the green and the red are split.
U hear grinding,squiling,motor noises,picture flicker black&white?This tv have a colors wheel.The problems u describing sound like the colors wheel it not functions correctly any more.
Jul 16, 2010 | Samsung HC-P4752W 47" Rear Projection...
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLN567W rear projection picture flickering
Your color wheel must be replaced. They are about $100 including shipping
Jan 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
I updated my lcd samsung firm ware and the picture went crazy .
you need to go into the service menu and adjjust the option bytes. When you upgraged you changed them. The other solution would be to replace the main pcb
Jan 08, 2009 | Samsung LN-R409D 40 in. LCD Television
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung LN-T4042H 40 in. LCD HDTV Logo
295 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
