Question about Canon PIXMA MX310 All-In-One Printer
Can't close scanner unit door on Canon MX320
..Just got this unit out of the box. I opened the scanner unit door to remove packing material and now I cannot get it to close. I have folded the support arm back but door won't close. It seems to be hanging up on a hinge support on the opposite rear side ...it has teeth on it. I hope it's something simple or back it goes. This is a Canon MX320 all in one.
Thanks!
Yes, it uses hydraulic mechanism to slowly close itself. Amazingly elegant design, but it confuses users who are not familiar with it.
Posted on Oct 15, 2012
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Canon mx320 error code 21550
Remove both power and usb cables completely then connect them and use the fastest usb port on your computer.
worked for me.
could also mean cables are old and needs replacing
Jan 22, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
Error 5100
1) Smearing or scratches on the timing
**** film;
clean the timing **** film.
2) Foreign material or paper debris that
obstructs the carriage movement;
remove foreign material.
3) Ink cartridge conditions;
re-set the ink cartridges.
4) Cable connection
5) Part replacement:
- Timing **** film
- Carriage unit
- Logic board
- Carriage motor
Aug 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Changing ink instructions canon MP240
With the printer on, open the paper output tray. Then lift up the scanner unit (with the document cover closed). Make sure the support is holding the scanner unit. Then wait until the cartridges move to the replacement area. Pinch the tabs together to open the cartridge locking cover (it just rotates up). Then remove the cartridge by pulling it towards you. Prepare the new cartridge - remove it from the box and remove the orange tape. Do not touch the electrical contacts or the print nozzles.
Slide the new cartridge into the cartridge slot (color on the left). Then close the locking cover - it should click into place. Make sure the cover is correctly closed. Lift the scanner unit to disengage the support and lower the scanner to close it. Wait for the printer to clean the new print heads before sending a new job to the printer. (It will finish printing a job that was in progress when the ink ran out.)
Note: if the scanner unit is open for too long, the cartridges will move to their home position. Close the scanner unit and reopen it.
You can find pictures of the procedure at Canon's support site: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport . Searach for replace ink cartridge. Altternatively, go to the Brochures and Manuals page and see the manual.
I hope this helps.
Mar 08, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I recently bought a Canon PIXMA MX320 all in one printer with my macbook. It works fine, but I can't figure out how to scan an image onto my laptop.
You need to control the scanner through your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" from the software.
Good luck, do rate the solution if helped
Nov 27, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
The FINE Cartridge Holder moves to the replacement position.
3. FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
I keep getting the following error on my Canon 980: C000 printer error has occurred what do i do?
C000 indicates to remove the packing material.
Remove packing material so that the print headholder can move. Confirm that the printer
is powered off.
Disconnect the power cord from the printer or at the wall outlet or both.
Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray
    After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1.Close the scanning unit cover.Reconnect the power cord and then power on the printer.
Jul 18, 2010 | Canon PIXMA MP980 All-In-One InkJet...
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon printer MP980 error code c000 what does it mean
HiHi this code is.
Remove packing material so that the print head holder can move. Confirm that the printer is powered off.
spacer.gif mp620_removepowercord.gif spacer.gif spacer.gif spacer.gifOpen the paper output tray and then lift up the scanning unit cover until it locks into position.
Pull the orange protective tape (A) in the direction of the arrow and remove the white plastic (protective material) (C).
    spacer.gif mp980_packingbeingremoved.gif spacer.gif spacer.gif spacer.gif After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1. Close the scanning unit cover.Reconnect the power cord and then power on the printer.
    Found this code on the net hope it helps you.
    All The Best: Pineworks
Jan 30, 2010 | Canon Office Equipment & Supplies
I am setting up a new Canon Pixma MP980. I lifted the scanner unit until it locked open to remove red packing tape and to have a look inside. Now I find I can't close the cover. How do I release the lock...
Over on the left there is a small two-position slide switch with pictures of an open lock and a closed one. Slide the switch to the rear (Open lock) and close the cover.
Nov 14, 2008 | Canon Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
117 people viewed this question
old marine
old marine
