Question about Sharp Aquos LC-20B2U 20 in. LCD Television
Power shutdown, F3701 blown, replace F3701, it's work awhile, then the set shut down power again. What's problem?
Thank you for your help.
  • Anonymous May 23, 2008
    Same as above fuse keeps blowing, install new one works for a while then blows and tv shuts off
    Sergeant:
  • 395 Answers
Replace the terminal pcb part # DUNTKB128DE03 you may be having a short in the secondary power supply. you can get the manual here https://www.vancebaldwin.com/shop/research_new/SHA/LC20B2UA.pdf to help you better trace the short. it can also be the main board too better to chase the problem than to make guesses.
Posted on Apr 19, 2008
I havd a Dell Dimension 8200 that sometimes shuts down and power light turns yellow. I can usally open case and plug and on plug to get it to power back up. Recently replaced fans due to fan failure....
Thank for the detail, it really helps...
Most people forget about the power supply. If the power supply overheats, it will shutdown. When shutdown, it will cool off then operate again.
A power supply goes by WATT ratings, the average size power supply is now 450 watts for an average system and should cost around $60.
good luck and don't forget to vote.
Oct 12, 2010 | Dell Dimension 8200 PC Desktop
Shut down
Go to the control panel select power option and check the settings.
Mar 30, 2010 | E-Machines eMachines Desktop PC
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
My Stilletto 10 doesn't reliably record programmed talk shows. I leave it on and plugged into my car kit (yes, it is powered by a plug that stays on when the car is off) and when I come back it is...
Is it set for auto shut down? It took me months to properly record with this thing, frustrating at best. Now it's almost flawless. Go in to menu then settings then dock. In that menu you will see "Auto Shutdown". If this is on, your receiver will shut off after 4 hours only when plugged into the car dock. When on a home dock it will stay on. Turn this off and it will stay on until you shut down. Auto shutdown is the default setting. If for some reason you receiver is reset, you will need to check this setting again, because it will turn auto shutdown on again. Hope this helps.
Jul 17, 2009 | Sirius STILETTO 100 MP3 Player
Smple script for graceful shutdown of Windows OS
a simple batch file could be used
down.bat
@echo off
IF "%1"=="" GOTO DEFAULT
IF "%1"=="a" Shutdown -a
GOTO END
Shutdown -r -t %1
GOTO END
:DEFAULT
Shutdown -r -t 30
:END
This batch file accepts the inputs as follows
"down.bat" This will shutdown in 30 secs and is default
"down.bat 120" This shuts down in 2 mins
"down.bat a" This aborts any shutdown operation.
Hope this is what your after
May 07, 2009 | HP 3000 XR (j4367a) UPS System
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Robert
Jan 19, 2009 | Dell Inspiron 5150 Notebook
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Fuse F3701 is blow-up after few munites turns on. If replace a fuse F3701 again, it work, but the set turns of any time, check the set: Fuse F3701 is blow again?
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Apr 16, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Power prob
blimey, these dv10s seem to suffer big from this problem.
check air filters,fans running.
if no input pj may shutdown by itself anyway
try connecting an input signal to see if pj keeps running
Feb 15, 2008 | Optoma MovieTime DV10 Multimedia Projector
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
Sharp Aquos LC-20B2U 20 in. LCD Television Logo
282 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
