Question about Yard Machines Garden
Acceleration issue on yard machine 13.0hp enduro el/c engine. When I hit the gas the engine bogs down. What should I check?
    Master:
  • 501 Answers
Fuel flow from the fuel tank.dirt in the carbie,blocked main jet,dirty air filter,blocked exhaust,running lean[somebody adjusted the main mixture too lean],.fouled spark plug,keyway on crank has allowed magneto flywheel to move,too high a load,loose carbie/intake manifold,choke on,
Posted on Jul 10, 2010
What would cause my 1990 chevy cheyenne to bog down while accelerating ?
The idle air control valve only controls idle speed.
The most common causes are restricted exhaust or air intake, or low fuel pressure.
Is the check engine light on ?
Oct 03, 2015 | Cars & Trucks
Why does my vehicle bog down when I accelerate from a start?
Try a different machine to read the codes then post a reply ,i have no idea what could cause this on this engine as remember that anything over 1.6/2.0 litre is regarded as a big negine here in europe ,most i work on are under 1.2 ,but if its not accelerating from idle then i would suspect a vacumn leak to one of the sensors but not having much practical experiance then i couldnt say exactly
Oct 21, 2014 | Cars & Trucks
I turn van on and go the van boggs down then the service engine light turns on and it smells like raw gas
Does it only bogg down on acceleration or all the time? If its only on acceleration you want to check for any loose vaccuum lines leading to the intake. In addition you want to check the fuel pressure at the fuel rail and make sure that the engine is getting fuel. If so check the injectors. A clogged fuel injector or one that is leaking can cause the bogging issue and the smell of raw gas.
Oct 25, 2012 | 1994 Chevrolet Astro
Would an idle control valve cause a car not to accelerate?
no, idle air control valve is literally to control your idle speed.
what happen when you press on gas? car shakes, RPM goes up, or engine just bogs down?
Mar 09, 2010 | 2004 Infiniti I35
Loss of power
You should have your cat. checked make sure there is no restrictions in your exhaust system.
Apr 11, 2009 | 1999 Chevrolet Tahoe
Accelaration loss of power
I'd have a fuel pressure test done to be sure, it isn't fuel related again. Takes 5 or 10 minutes so cost should be minimal. The other thing that comes to mind is a plugged exhaust. (catalytic converter) Quite possible on a 10yr.old vehicle.
Apr 11, 2009 | 2004 Chevrolet Tahoe
Bogs out when i accelerate
plug wires!? They go bad over time, but may still look ok from outside ... get an ohm meter and pull a wire and check ... more than 500 ohms per foot is no good..... Good high quality wires will be no more than 150 ohms per foot.
Apr 07, 2009 | 1990 Jeep Wrangler
Engine bogs down between 35 and 45 spongy accelerator
Check the MAF sensor and the fuel pressure
Oct 22, 2008 | 2008 Subaru Forester
Garden Logo
125 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
