Question about Maytag Atlantis MDE7400AY Electric Dryer
Something (like a lolli-pop stick) got through the
I have a Maytag Atlantis clothes dryer. Something (like a lolli-pop stick) got through the lint trap and is rattling on something in the duct. How do I gain access to this area to clear it?
  • 348 Answers
If you can't get a vaccum hose through the lint trap and **** it out then you may have to remove the lint vent pipe in the rear. Reach up in there or try sucking it out with the vaccum. If no good then you may have to remove the rear panel and then do a good cleaning. Your vent duct maybe able to take apart finding the noise. At this point it maybe more trouble than it's worth.
Posted on Jul 11, 2010
Where is the lint filter? Why does it put lint all over clothes?
lint is usually removed in the dryer. If you have lint on clothes after going through the wash, you probably left something in a pocket somewhere.
Sep 20, 2014 | Maytag Washing Machines
I have a Maytag Atlantis Dryer Model MDE6400AYW - it is making a loud screeching noise which seems to be coming from the rear of the dryer. I have unplugged it and removed all the lint from every possible...
If you remove the screws from the lint trap shute, unscrew the 2 screws on the back side of the control panel, on the outer back, and take a flathead screwdrivew or putty knife to the front corners of the lid, you can pop the tabs and lift the top to remove the front of the dryer, to access the drum and motor.
Apr 10, 2011 | Dryers
My maytag atlantis dryer heats up but on any cycle the dryer doesnt run long enough to dry the clothes i have to turn it on two or more times to dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Lint problem
Yes, check filter assembly is not blocked.
Mar 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
When the dryer is on it smells like something is burning
iF YOU USE DRYER SHEETS IN YOUR DRYER, YOU MAY WANT TO WASH, BY HAND, THE SCREEN IN YOUR VENT. tHE SHEETS BUILD UP A COATING ON THE SCREEN AND IT WILL MAKE YOUR DRYER WORK A LOT HARDER AND MAY CAUSE THE SMELL.
Oct 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Lint on clothes
hi thanks for the question sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let stand for 4or 5 hrs . now drain the tub should work thanks for the question the appliance doc
Sep 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fluff left on clothing
Maytag Performa Washing Machine!!
All our clothes are being ruined with continuos fluff sticking to items.Have tried hot wash -no clothes, same problem.
Have tried not using Fabric Softener still no solution.
guest
Aug 14, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MDE7400AY Electric Dryer Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
