Question about Lexmark X1150 All-In-One InkJet Printer
Is it only compatible with certain computers and i dont have the disk where can i find it online
How do I burn files to a disk to play in DVP3140
I'm assuming you're using a recent-build Windows PC. Here's the link from Microsoft: http://windows.microsoft.com/en-us/windows-vista/burn-a-cd-or-dvd-in-windows-media-player. Media player must be recent enough in version to burn disk media--otherwise, you must obtain a software product that will burn media for you. Your PC must also be equipped with a CD, DVD, or Blu-Ray burner. CD-R disks easily prove available from discount stores, music stores, electronics stores, or online.
As for compatibility, Phillips indicates that CD-R is compatible. I hope that you don't have a problem. That depends upon the media manufacturer and how its product interacts with the Phillips. Compatibility likely won't prove a problem. Certainly, check that out before the next trip....
Aug 20, 2013 | Philips DCP851 Portable DVD Player
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
Hi i bought toshiba c640 laptop i want play gta game is it good to play or not pls tell me
Hi It would with better if you will use joystick controller to enjoy playing GTA , Its just like your playing game console by using joystick controller. You check the price of joystick controller for your computer online or nearest computer center
-The specification of your computer meets the system requirements and I believe that your not going to have any problem installing GTA also playing GTA.
Minimum System Requirements:
800 MHz Intel Pentium III or 800 MHz AMD Athlon or 1.2GHz Intel Celeron or 1.2 GHz AMD Duron processor
128 MB of RAM
8 speed CD / DVD drive
915 MB of free hard disk space
(+ 635 MB if video card does NOT support DirectX Texture Compression)
32 MB video card with DirectX 9.0 compatible drivers ("GeForce" or better)
Sound Card with DirectX 9.0 compatible drivers Keyboard & Mouse
Recommended System Requirements
Intel Pentium IV or AMD Athlon XP processor 256(+) MB of RAM
16 speed CD / DVD drive
1.55 GB of free hard disk space
64(+) MB video card with DirectX 9.0 compatible drivers ("GeForce 3" / "Radeon 8500" or better with DirectX Texture Compression support)
DirectX 9.0 compatible sound card with surround sound
Gamepad (USB or Joystick Port)
Keyboard & Mouse
Oct 26, 2011 | Computers & Internet
New computer has windows 7. When I try to use Word Whomp disk it tells me it is not compatible. Is there a patch I can get?
I can't seem to find a patch but try right clicking on the program, going to properties -> compatibility and running it in XP or Win 98 compatibility mode.
There is actually an online flash version:
http://word-games.pogo.com/games/word-whomp
Hope this helps!
Jul 04, 2011 | EA - Electronic Arts Word Whomp To Go for...
I want to stall the window xp3 how i do that
First try getting your hands on an install disk. i would suggest first that you look your computer up online to make sure it is compatible with xp. after that simply start your computer up and hold either F12 or F2 to enter setup, from there (with the disk in the computer) set the boot order so that it boots from the disk, after hit save changes and exit and follow the instructions on the disk to install windows xp
Jun 07, 2011 | Microsoft Windows XP Professional
Seagate 80GB hard disk
Dear
Your jumper setting is wrong.your elected is none ata compatible .plz set the jumper setting master or slave.
Jul 19, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How can I make my computer run faster?
1) Download a programme called Ccleaner from Filehippo.com and clear out all the garbage on your HDD.
2) Take the cover off and clear out all the dust that has accumulated.
3) Add more RAM. (Check compatibility)
4) Higher spec CPU. (Check compatibility)
Apr 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I cannot connect my canon mp460 all in one printer to my new asus laptop?
Some copiers are not compatible with certain computers.You might need to get online and go to asus website to see which copiers is compatible with your computer.
Feb 26, 2010 | Office Equipment & Supplies
WHAT PRINTER IS COMPATIBLE TO MY CANON S520
What computer do you have? You can download drivers from the Canon website.
Jun 16, 2009 | Canon S520 InkJet Photo Printer
Want to try to utilize an old sony Vaio PCG-F520
OK you can certainly add wireless to this machine. But be careful which type you buy. If this machine has windows 98 you have to ensure the wireless adaptor will be compatible. . you have two choices for the adepter type either USB or PCMCIA (aka PC Card) I'd go for the PCMCIA version, it will be more likely to play well with the older system. Also, Dont buy a MIMO card, a simple 802.11B or 802.11G compatible card will work. these are in the sub $40 price.
Dont attempt to install XP or VIsta on this PC, it will be unbearably slow. Stick with 98 or better yet windows 2000.
-Good Luck
Jan 05, 2009 | Sony VAIO PCG-F520 Notebook
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
