Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer heats up but dosent rotate - Maytag Atlantis MDE7400AY Electric Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be an issue with the belt, please check this video on how to replace the belt in dryer. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
Dryer vent was cloged now heat dosent work
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-200-865057-/LG-Dryer-doesn-t-heat-DLEX2501V
Sep 01, 2014 | LG dlex2501v front load steam electric...
Drum rotates no heat,igniter dosent start
While the drum is rotating you should hear the CLICK associated with the gas valve assembly powering up to give out a blast of heat. If ya don't hear no click check the duct fuse. Right next to the control thermostat. If it is blown it kills the circuit to the gas valve assembly. If that fuse is good and the control is also good, then check the flame sensor for continuity, If it is open then the ignitor won't glow. The ignitor must glow and change in resistance then the flame sensor must open up and kill power to the ignitor so that power will be shifted to them coils on the gas valve.
Sep 03, 2011 | Maytag MDG2706A Gas Dryer
Dosent heat up element tests good
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 06, 2010 | Kenmore 63942 Dryer
Dryer dosent heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 14, 2010 | Dryers
Dryer dosent seem to be heating up all the way
heatman101
rt45gf
Dec 28, 2009 | Frigidaire GLGR331A Gas Dryer
Dryer does not heat. It does rotate. Any ideas?
The heating is either a blown fuse or element and the rotating is the belt that has come off or broken or worts case the motor has packed up
Dec 28, 2009 | Whirlpool LEQ9858P Electric Dryer
The fun does not rotate
Hi!
Try to vacum the dust way from the fan, and try to blow the dust u cant vacum whit compressed air.
If that dosent help you need to buy a new fan. Be carefull so your laptop dosent overheated, the heat cam make big damages inside your laptop.
Good Luck
Nov 20, 2008 | HP Pavilion ze2000 Notebook
Dryer challenge
take off top to see if belt is ok
Mar 14, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
