Question about Century Body Opponent Bag
I have a cut in the neck of my bob body opponent bag. its about 1 inch long right on his neck. how can i repair the cut?
  • Anonymous Mar 23, 2014
    need pn for black piece that attaches to rubber dummy
  • 252 Answers
Due to the material that is used, I'd get some fishing wire and sew the cut up. Stitch it normally, then go back over cross-stitching to get double the holding capacity.
I'd then use some doctors tape, it's very sticky and will keep the cut together.
I know this sounds like doctors and nurses but it will work. Fishing wire isn't going to snap, the only problem I can see is the bob body might hang its head slightly when you pull the stitching tight. Either way a cut to the neck will make him look hard as nails :)
Hope this helps. Your vote counts a lot. Thanks.
Posted on Jul 13, 2010
What was the class action lawsuit about and why the payout?
on bags.? SRS malfunctions?
the maker ,of the bag, made defective propellant SQUIBs.
why pay out? because they are culpable.
the SQUIB, ruptures, (in a bad way) causing flying plastic, (think shrapnel) to hit divers neck cut it and you bleed to dead.
cupable. is the word
if the bag bruised you. no foul (common) but cut neck, oops
lawsuits.
IMO. why not google this and read the full story,
Oct 06, 2014 | Toyota Corolla Cars & Trucks
How sturdy is a body punching bag device?
Technically, you can hit a BOB bag with the same amount of strength you would a traditional heavy punching bag; however it would defeat the purpose. When you hit as hard as you can your aim is to develop power, strength and stamina. These are not the same goals you would be working towards training on a BOB.
Aug 07, 2012 | Boxing
What's an Air Hockey gameplay?
The games play as described by USAA:
  • The mallet is gripped behind the knob using one's fingertips, not on top of it. This allows more wrist action and helps the player to move the mallet around the table faster.
  • For basic defense, the mallet is kept centered at least 8 inches out from the goal. In this position, very slight movements to the left and right will block virtually all straight shots. To block bank shots, one pulls back quickly to the corners of the goal. This is known as the "triangle defense".
  • Shots are often hit out of "drifts", where the puck travels in set patterns designed to throw off the opponent's expectations and timing. The most popular drifts are the "center", "diamond", "diagonal", and "L".
  • Shots are often organized into "combos", meaning groups of shots which are hit with the same apparent delivery but opposite directions, caused by hitting the puck at slightly different locations on the mallet. For example, a transverse motion of the right arm can lead to a "cut shot" to the left corner of the opponent's goal or a "right wall under" (bank off the right wall, into the right corner of the opponent's goal).
Jul 25, 2012 | Sport & Outdoor - Others
How do you fix the bob when it has a tear in its neck. the head is starting to come off.
I had the same problem, started with inch long tear in his adams apple ,eventually more than half his head was fallin off. I took a nice sharp knife and pirced a hole an inch above and below the tear every 4 or so inches and stuck zip ties through em. Feed the end of the tie through the top hole going inward. Do all the top holes like that. Once your done with the top feed the now inside ends of the ties outside through the bottom holes. Do this all the way across, THEN feed the ends through the locks and zip em tight. i then put a scarf on his neck to hide the tie ends, or i suppose you could tape em down. I dont think striking the ties will do any damage to your hands it just looks tacky. Make sure your holes are atleast an inch away from the edge of the tear so the ties dont rip through the "skin" inbetween them.
Jun 19, 2012 | Century "Bob" Body Opponent Bag
Century bob
Cheap plastic nipples are stripped out! Moving it while Bob is still attached & kids jumping on Bob's shoulders did the same to mine... I am going to try short bolts & nuts after dipping in plasti-dip/rubber product of some sort.
Nov 21, 2011 | Century "Bob" Body Opponent Bag
How do i replace the neck on my gas tank
1)Open the gas door and unbolt the gas filler neck from the body of the vehicle, using a 1/4-inch ratchet and socket.-------
2)Crawl underneath the vehicle, and use a flat-head screwdriver to disconnect the fuel filler neck from the gas tank. There is a hose clamp that secures the rubber hose to the tank, and a breather tube as well. Work the tubing off the tank using your hands.--------
3)Pull the gas filler neck out of the gas door by hand. You may need to twist it around to snake the tubing through the body of the car, but it will come out.------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 19, 2010 | 2001 Oldsmobile Aurora
Need replacement parts - accessories
If the kickback arm you seek is the type that is a round bar with pointed fingers on the bottom, I had the same problem. (different model DeWalt) I gave up trying to find one, and finally just made one. It was pretty easy, and works very weill I bought a piece of steel rod (1/2 inch I think) a steel repair plate (from which I cut a pair of tear-drop shapes with a hacksaw and file) a 1/4 inch hex-head bolt (which had about 1 inch not threaded) and a 1/8 inch roll pin. I looked at various pictures on the web to determine the shape of the teardrops. I drilled a 1/4 hole in the 1/2 rod. I cut the threads off of the 1/4 bolt so it was still long enough to accept the 1/2 rod, the two teardrops, 2 washers and the 1/8 roll pin. Then I put an 1/8 hole in the bolt allowing enough clearance so that the teardrops would swing freely. It works like a champ. One minor flaw is that with only two of the teardrops (instead of several) and being separated by 1/2 inch, it would be possible to make a skinny enough rip that only one teardrop would contact the board being ripped, leaving the other peice unguarded.
Jan 23, 2010 | Delta Machinery 10" Professional Radial...
Do you have the instructions for dokapon?
Hi....here it is:
Gameplay Controls Printable View Dokapon Kingdom GAMEPLAY CONTROLS:
wii_dir.gif Control Pad Move. Move Cursor. Up = Magic (Battle). Left = Strike and Counter (Battle). Rock (Roshambo). Down = Skill (Battle). Give Up (Battle). Scissors (Roshambo). Right = Attack (Battle). Defend (Battle). Paper (Roshambo). wii_a.gif A Button View Shortcut. View Space. Open Help Menu. wii_b.gif B Button Bag Shortcut. Display the World Map. wii_1.gif 1 Button Cancel. Movement Shortcut. Data. Show Information. wii_2.gif 2 Button Make Selection. Confirm Message. Stop Spinner. Show Available Moves. Speed Up Cursor. Show Predications. wii_minus.gif - Button Flip Page. Switch Between Opponents. wii_plus.gif + Button Data Shortcut. Flip Page. Switch Between Opponents.
Aug 05, 2009 | AIA Dokapon for Game Boy Advance
Koakako
Hemline Studio Collection Sewing Machine Bag $34.95$29.99. Click for more info · Hemline Studio Collection Serger Bag $34.95$29.99. Click for more info ... Category > Sewing Cases','www.sewingmachinesplus.com');">http://www.sewingmachinesplus.com/sewing-accessories-cases.php
callthis number tell ur model
Click on the link for information on the available bags. You can order the bags through Bob McDougal's by calling 1-877-408-7005
Sep 17, 2008 | Singer 7462 Mechanical Sewing Machine
Century Body Opponent Bag Logo
375 people viewed this question
Top Century Sport & Outdoor - Others Experts
Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
