Question about Garden
When I disengage the blade, I'm not sure it's disengaging, and then I hear a loud click sound. I'm thinking maybe something is preventing the immediate disengaging of the blade, but I'm not sure.
  • 1,284 Answers
Hi, it sounds like the cabel is bad it this model has one but if it doesn't then the Engagement is bent.
Take care
Posted on Jul 10, 2010
John Deere eztrak mower went over a rock today and now the mower won't engage
hmm strange are the belts driving the blades ok if so then the PTO could be damaged but if there's no sign of damage it maybe a bit frozen up/locked up have the engien off but turn the key on and engage the PTO switch and manually turn the PTO (not by the blades please....dont want to have your hand taken off) turn by the PTO itself and if you hear any clicking sound disengage the PTO and engage a few times to ensure your hearing the clicking sound of the PTO turning on and off and it should be back to normal also check any connections going to the PTO before doing the manual work of repairing the PTO
Apr 22, 2017 | John Deere Garden
Craftsman lt2000
Your blades engage with a cable and the cable somewhere is bunched up. You will probably need a new cable.
Aug 05, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Cubcadet LTX 1045 blades disengage for no apparent reason.
I don't think it's wiring. If it were, the PTO clutch should disengage.
In your case, it's not. To me, it sounds more like a mechanical load on the blades or possibly bearing gone in one of the blade pulley assemblies.
Oct 19, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Loud noise when clutch is disengaged
Something is locked up underneath, something is preventing your belt from spinning. I recommend going under and inspecting the blade area and also belt area especially if the deck is full of debris. You might even have a frozen bearing or something like that anyhow you need to do a little investigation, pronto buddy. Good Luck
Jul 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Bearing noise?
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Swisher 44 Iinch 11.5 Hp Trailmower...
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
