Question about Bosch DHMUZ4MX2 Blender
Loose blade. I have a loose blade that squeals when I start it.
    Genius:
  • 1,970 Answers
Mcdevito75 here, It could be a sealed bearing in the motor you here, Check online with Bosh Blender .com, contact them. Or see an appliance repair shop in yout area, if it is a bearing in the motor, a replacement blender may be your best bet.
Posted on Jul 10, 2010
I have a vitamix 5000 unit. Blade assy makes noice ; is loose. Where can I buy the set of bearings for the blade assembly?
You will need to source them from a bearing supply company as Vitamix only supply the bearings as a complete unit with the blade assembled. Once you have the bearings out take the sample with you to the bearing supply company for correct identification.
Jun 27, 2017 | Vitamix Blenders
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
My K-Tec Champ HP3 is overloading and shutting off after about 5 seconds even with the jar empty or not even on the machine. It just starts up and shuts off (displaying "OVERLOAD" on the...
Remove the 2 screws from the bottom of the base, release the 4 clips on each side and remove the bottom cover.
There is a fan blade attached to the bottom of the motor and a sensor on the side of it that senses the fan blade turning. If the sensor does not sense the fan blade turning, it assumes that the motor is locked up or 'overloaded'.
Check that the fan blade has not come loose from the motor shaft and reattach if necessary. Verify that the sensor is secure in it's housing next to the fan blade.
Reinstall the base cover and verify operation.
Jan 24, 2011 | K-Tec Champ HP3 Work Top Blender
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
My blender won't blend. Everything turns but the blades.
I have no idea what might be turning, but likely you do not have the blades seated if the shafts don't turn... IF the shafts turn, the welds or swaging of the baldes to the shaft have probably come loose due to overloading.
Apr 07, 2010 | Bosch Blenders
How to remove the jar base? In order to thorougly clean the jar you need access to remove the gasket, blade assembly, and jar base.
It just unscrews CCW. If it has never been romoved it may be quite a task to get it loose. Do not loose the rubber gasket in the process of cleaning it. You will never get another one without buying the whole assy.
Mar 10, 2010 | Blenders
Unit seems to work fine, but when the pitcher is attached, the blade hardly spins. It seems like it is loose or something. I can manually spin the bottom piece of the blade assembly, but the blade itself...
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
Jul 27, 2009 | KitchenAid KSB3 Classic Work Top Blender
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Jul 10, 2008 | Blenders
Bosch DHMUZ4MX2 Blender Logo
133 people viewed this question
Top Bosch Blenders Experts
eyecam
Are you a Bosch Blender Expert? Answer questions, earn points and help others
