Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
I have a whirlpool refrigerator. I have water
I have a whirlpool refrigerator. I have water accumulating under the veggie bin. How do I solve
  • Kenmore Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorI have a whirlpool refrigerator.  I have water - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
I have freezing water at the bottom of my fridge under the veggy bin,how can i solve this problem.please help thanks
You might want to turn the refrigerator and the freezer to lower settings and check the damper in refrigerator compartment and make sure that it is not open all the way. Try a setting of "3" on both freezer and refrigerator and adjust accordingly if needed.
Dec 12, 2010 | Refrigerators
Water is leaking in my fridge, a puddle of water accumulates under veggie bins. Can I fix this problem? If so how? or do I need to hire a professional?
if you want to attempt fixing, remove back freezer panel, use hair dryer to melt ice in drain pan under coils, pour hot water in pan till drain clears.
Sep 01, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
I have a whirlpool model GS6SHEXNQ00 that i purchased 3-1-2005. Recently I have been getting water in the bottom of the freezer. Could this be caused because the water chute may be frozen solid. (This is a...
Have you changed your filter for the water/ice? If, not this can be the problem. We recently had this issue with our Frigidaire we were leaking water under the veggie bin so badly even leaking on the floor until we finally changed out the filter for the ice/water machine. I hope this solves your problem.
Mar 01, 2018 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is collecting in veggie bins in
I can solve your problem for you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 11, 2009 | Refrigerators
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Locate evaporator condensate drain tube
next remove the evaporator fan cover and under the evaporator will be a silver tray with a hole in it this is the drain for the defrost systems and some times they get frozen the best way to clear them is with a eureka 350 hand held steamer you can get at Lowe's fairly cheap you can also find about 1000 other uses for it a round the house
Jan 26, 2008 | Refrigerators
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
