Question about Microwave Ovens
My maytag msd2454gr stopped cooling and freezing today. can you help?
  • michaelan969 Jul 10, 2010
    my maytag msd2454gr stopped cooling and freezing today. fans blowing air but not cold. help me ....
  • 2,272 Answers
First of all check the freezer coils and freezer fan motor . Is the freezer fan motor running. Yes the coils are behind the freezer panel open the freezer door and its straight ahead of you.clean the coils under the fridge where the compressor is located. Either the coils are over frost and the ventilations are blocked or the compressor itself is not functioning properly. It has to be checked. Open the panels in the freezer and notice the  drain area.If its frozen then this can be one possibility.there is a small rectangular hole between the fridge and the freezer which is basically by the drainage hole of the freezer and behind the storage racks in the fridge side.Check out if this hole is clear or blocked. Check out the coils beside the compressor.If the coils are dirty the coils needs to be cleaned.
There is a fan next to compressor  that's blowing air through some spiraling coils to the right of the compressor. Also check out if that fan is running or not. ------- So for the first thing to be tried is reset procedure. Unplug the unit from main power outlet.Keep the doors open .both.Then Empty the unit completely.Let it remain like that for 24 hours.All the water will leak from the unit due to ice melting in the unit. Then after 24 hours.Just clean the water normally.Then re connect to the power outlet and check after 2 hours.It will work properly. But if its not working then its the problem of the above mentioned possibilities.Most probably this problem relates to compressor. But still try all the cleaning procedure and check out both the freezer and lower section fan in the unit.If the fans are not working then that is the reason. Replace the faulty part to get the problem solved. To get required parts for the unit.You can get it from  www.repairclinic.com Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
    the compressor is clicking on for about 8 to 10 seconds and then off every few minutes what does this mean? the bottom of the freezer had accumulated ice and i got it all out and made sure the hole between the compartments was free of ice.
  • raj somaiya
    raj somaiya Jul 11, 2010
    The compressor should run for unit getting cold.If its not running properly then either the start up capacitor beside the compressor is faulty or the compressor itself is getting short and due to that its got weak and not functioning properly.It has to be checked with meter and replaced if faulty.
    Thanks for keeping updated with your query.
  • 10,515 Answers
There are few Steps that you could Verify and narrow down the problem :-
1. Compressor - Make sure that the Compressor should be working. When you ON the refrigerator, you could hear a clicking sound from the Compressor.Compressor could be Hot but not enough to lay eggs on it.
Note - In case, you find that the Compressor is Clicking and Shut Down the machine every now and then, more often that's an indication of Faulty Compressors. With most Brands, they do come up with 5 Years Warranty.
2. Make sure all the Fans are Working. I have seen many times, that the Fans are not working and the people are Inspecting other Components in the Refrigerator.They should also be running at Optimum Speed.
3. Do you see any Ice in the rear of the Freezer? More often - Frost. ( Not Crystal Clear ). If yes, take a Blower / Dryer and melt it. You would see a complete Difference.
4. Make sure that the Condensor Motor is working. If you could hear Condensor Fan is running, it always indicate that the Motor is Fine too.
5. How many times we never clean up the Evaporator Coils? We are using it for Years and we never clean it. So, if this is the Case, time to Take a Vacuum and clean the Evaporator Coils.
6. It could be a Defrost Problem. There are many Components but How could you make sure?
The Best Way - Disconnect the Power Supply and Unplug the Cord. Take everything out of the Refrigerator. Keep the Doors Open for 24 hours. After 24 hours, plug in the Cord and then Turn ON the refrigerator.If you see that there is Some improvement, more likely you have faulty Defrost System.
7. On other Occasions, i have Found Overload Relay to be one of the reasons. I solved many Problems where the Customer Actually Test and Find that the Overload Relay is at Fault.
Note - There could be Freon Leak or Gas Leak which i am not considering right now. You need to contact a Licensed Professional to check these.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
My fridge freeze is excessively freezing in the freezer compartment and not chilling in the fridge compartment Any help would be greatly apprieciated Brian
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Microwave Ovens
Freeze is working good , not the other side
heatman101
Aug 31, 2011 | Microwave Ovens
My fridge is warm doesnt cool down the things inside only the chilly colder box is cold and it freezes down the meat
heatman101
May 19, 2011 | Bosch Microwave Ovens
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
Our Maytag MVP V was operating when something sounding like a circuit blowing blew out the 40W over-stove lightbulbs. Replacing the bulbs didn't help and my wife says the microwave now makes an odd sound...
Hi Jim9000 I am Kelly and I just started doing this on-line Jan 2010. Today I happened across your (GADS!) 15 Oct 2009 microwave post. I am assuming by now you have had it serviced but if not reply here and we will go from there. Thanks.
Oct 15, 2009 | Maytag MMV5186A Microwave Oven
Maytag MMV5000 stopped working
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 04, 2008 | Maytag MMV5000 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
