When i turn the thermostat on outside AC unit comes on but inside blower motor does not.
  • 2,272 Answers
It needs to be checked. It could be a thermostat problem or it may be a bad blower motor or blower motor capacitor. Try turning your thermostat to the fan on position to see if the blower will start manually. If it does you most likley have a stat problem. If it does not start you will need to isolate the blower motor wiring and check to see that the motor has voltage. If it does then the blower motor is bad.then either the motor itself is bad, or the capacitor is bad. The capacitor is the cheapest thing to replace, so if you can't test it, then just go ahead and try that first. Also, make sure that there are no loose wires anywhere. --------- If you have a circuit board and no relays, then your blower is being controlled through a small relay that is part of the circuit board. You can trace the black/red wires from the blower motor to see where they connect - chances are they connect to a small black cube on the board. That is the relay. If you have access to an amp/volt meter you could check to see when the motor gets power from the board and how many amps it draws on start. This would be the easiest way to determine the cause. If you don't have access to a meter, you are kind of stuck either changing the motor or the board. Here is something you could try. Set the thermostat to OFF. Open up the air handler and disconnect the control wire that is connected to the G terminal on the thermostat (should be the green thermostat wire). Connect a jumper wire to the R terminal on the air handler. Touch the other end to the G terminal several time to see how the blower responds. You should hear a clicking on the circuit board as the relay responds. If everything seems to be responding properly, with the green wire still disconnected, set the thermostat fan switch to the ON position. Now take the green wire and touch it several times to the G terminal. If things do not respond as quickly and in the same manner as with the jumper from R, then there is a problem in your thermostat or control wiring. If things don't respond properly, this still doesn't tell you if the problem is the board or the motor, but at least you will have completely eliminated the thermostat and control wire.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
Why when ac is turned on motor is off and nothing blowing from vents
Is the outside unit running? If it is you either have a blower relay out or your inside fan motor is bad. If the outside is not running you turn on the fan on the thermostat to ON not auto to see if the fan motor comes on.
Jul 15, 2014 | Heating & Cooling
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Cooling begins then indoor blower stops...outside unit continues to run
I had the same problem,if you do not monitor that you will make matters worst and burn the Compressor.your problem is the blower unit it has three speed sometimes four.it needs to be changed..
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Blower never stops. AC outside jammed to stay on???
You need to call someone who truely knows what they're doing. From your decription, the person you had out should not be working on units. You have a problem most likely caused be the person that installed the new motor and these units are not designed to be worked on by the homeowner. There are hazards that could cause damage or injury.
Aug 18, 2009 | Goodman CLJ36AR42 Air Conditioner
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
My blower inside my house will not come on. outside unit either
Initially, it doesn't sound like your thermostat is working.
If it has a setting to allow the blower (air mover) to be operated alone or continuously, try that.
Generally, if the inside unit (air mover) won't power up, the outside unit will not turn on for more than a couple of minutes because if the inside unit isn't working, pressure builds up in the lines going to the outside unit and an over-pressure sensor will shut it down again.
Jan 09, 2009 | Friedrich QuietMaster Electronic SS12J30D...
I thought the blower motor on my electric furnace was out so I replaced it with a GE 1075, 1/3hp new blower motor. I still have the same problem though. When the outside unit turns on the blower motor...
It could be a bad thermostat. remove the front cover, take a jumper wire from r to g to see if the fan will come on, if does then its the thermostat is bad, if don't, then the fan circuit board is bad.
Sep 12, 2008 | GE Heating & Cooling
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
