Question about Troy Bilt Tb70ss Gas Trimmer
Fuel line routing form TB90BC - Troy Bilt Tb70ss Gas Trimmer
  • 1,284 Answers
Hi, i don't really understand what you mean by fuel line routing form TB90BC.
Take care
Posted on Jul 10, 2010
  • patbuckley Jul 10, 2010
    fuel line routing for TB90BC trimmer
Need to know what 3 lines from fuel tank go
The pump line, or feed line, goes to the fuel filter and then to the engine's fuel rail. A return line leaves the fuel rail and sends gas back to the tank. Usually, the feed line is slightly larger than the return line, not always.
The third line is a vent line for emission controls-routing gas fumes from the tank to the charcoal canister, where it is stored and later sent to the engine to be burned.
May 31, 2015 | Cars & Trucks
2001 Hyosung Kaliber 50 fuel line routing
Hi, Michael for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Hyosung, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2001 Hyosung Kaliber 50 fuel line routing Google Search
Vacuum and fuel line routing
Hyosung Sense SD 50 Service Manual
Hyosung Parts Scooter
HYOSUNG TE 50 Owner Manual
Dec 13, 2014 | Hyosung Motorcycles
Poulanprop fuel line routing diagram
in 1980 it is pretty much forward from fuel tank to fuel pump from fuel pump to carburetor ....the return line from pump to tank
hope it helps
Apr 06, 2014 | GMC C1500 Cars & Trucks
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
TB90BC WON'T START
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ``
Feb 06, 2012 | Troy Garden
Need diagram / pictures of routing of all fuel lines. 1981. CX500 Custom
It's hard to find diagram for older bike.
I got the pic from the tank to pet ****.
LINK HERE
Aug 10, 2011 | Honda CX 500 B Motorcycles
Troybilt TB90BC fuel line schematic? I have replaced fuel lines that degraded with age and am uncerttain about the correct hook to tank, carburetor and primer. A diagram would help
easiest way to tell you is that the primer is there to pull the fuel through the carb. so fuel filter line goes from tank to carb, then from carb to primer and then back to tank as a return. if you forget which is the in line for the carb just hook with gas in a jar and try sucking it out of the jar. put filte rin a jar. and run line to carb , then line out of carb to primer and line back to jar as a return. if it pulls freely and fills the primer bulb your ready to go. if it pulls hard or not at all something is wrong.
Aug 15, 2010 | Troy-Bilt Garden
Troy-Bilt weed eater, Model TB90BC, had rotten fuel lines and primer bulb, I replaced but may have hooked them up wrong. How do I hook them up?
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
Apr 04, 2010 | Troy -Bilt String Trimmer/Blower...
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
493 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
