Question about Apple iMac G4 Desktop
What to do when rebooting Mac and folder with ? is flashing
In middle of screen?
  • Apple Expert
  • 481 Answers
This icon is an indication that the computer cannot find a working hard drive; or if it has, that it cannot find a viable OS on that drive.
Shut the machine down to power off. Now turn it on and hold down the option key. Do any hard drives appear on the screen? If not, your hard drive has gone bad or has somehow disconnected itself. If so, choose that drive and hit the return key. If your machine boots, login and use System Preferences / Startup Disk to re-establish this drive as your startup drive. If not, this drive doesn't contain a working OS.
Posted on Jul 14, 2010
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
My mac powerbook is displaying a folder which flashes between a question mark and a icon in the middle of the folder it stays on the grey start up screen and doesnt start up any suggestion???
Your PB can't find the system. Most likely you hard drive is no longer working. To check that this is the case, start up from the discs that came with your computer.You will need to replace the hard drive then re-install the operating system off those discs. I hope you had a backup of your data!
Feb 21, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Help
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the Mac, and hold the "C" key with your installation disc in. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
Jun 10, 2009 | Apple iBook G3 Mac Notebook
Flashing folder with a question mark in before it loads up to the password question.
It sounds like you have spyware on your machine that is causing the problem.
Go to www.superantispyware.com and download the free spyware remover. Once you have installed, updated and done a complete scan reboot the computer and see if you get the same problem.
May 25, 2009 | Apple Mac OS X Server for Mac
Screen goes white, flashing a folder with a question mark
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk.
Insert the disk into the computer and it will boot from that and take you through the install procedure.
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Grey screen folder icon flashing and alternating with ?
The computer can't find an operating system. Start up from the OSX disc and check the drive with 'Disk Utility'. The system may have got damaged, or the drive may need to be repaired. Run 'First Aid'.
Apr 10, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Flashing Folder
you are having main-board issues and possible harddrive issue.
but the mainboard can cause drive failures your info might be fine,The blue screen indicates a board error(memory usually)
Aug 09, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
E mac computer
Is it a file or Folder on the screen?
Are you booting in OS9 or OSX?
Simple answer without knowing the answer to the above questions could be the hard drive is bad. Try rebooting with the install cd's that came with the machine. If you see a disk image it is good if not it is bad. If in Os9 it is a corrupted system folder and that could mean many issues have occurred.
Apr 28, 2008 | Apple eMac G4 Desktop
Apple iMac G4 Desktop Logo
97 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
