Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
The satellite will not turn on
The only light on the system that will turn on is the TV 1 green light. And it occasionally blinks every few seconds from time to time. Nothing comes on period. I checked the cables, reset the system, unplugged it etc etc, but to no avail. It simply appears to be broke.
Thanks
  • Official Brand Answer
  • 263 Answers
Hello, my name is Tommy Faust with DISH Network Customer Service. I understand how frustrating this problem can get.
If you're still having the issue, what it's doing is called Boot Recovery. It needs to finish the recovery process and should power back on fine.
I hope this helped! Feel free to get back to me here if you have any further questions.
Posted on Jan 08, 2011
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Siginal is lost and can't turn the system when I want to. The only light on the system that will turn on is the TV 1 green light. And it occasionally blinks every few seconds from time to time. Nothing...
Hi
First get ahold of Dish Network and have your dish realigned. Sometimes excessive wind or birds can move the dish away from it's optimum recption. At this point also, the repair person can tell you if the equipment is bad.
Aug 23, 2010 | DISH Network DVR-625 DTV Receiver /...
I need the code for sharp tv please
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Apr 22, 2010 | Jensen SC-570 Remote Control
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
221 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
