Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
We have the GE smart water filtration system below our kitchen sink that uses the FXUSC replacement filters. It is our first time changing the filter and we do not know how to open the glass canister. Any info would be helpful. Email response to Atlasglassinc@aol.com thanks
  • 10,865 Answers
Hi. Here are the steps:
Turn off water to filter by rotating the by-pass
valve to the by-pass position.
Press the red pressure release button to release
pressure.
Unscrew the filter canister and discard used
filter. Wash the filter canister with mild soap
and water. Do not use harsh cleaners or hot
water.
Inspect the filter canister O-ring. Make sure it
is lightly lubricated and completely seated in
the groove. It is recommended that you
replace the O-ring if it is damaged.
Place a new filter cartridge into the canister
making sure it is centered and completely
seated on the bottom seal.
Reinstall the filter canister to the unit. Hand
tightening is all that is required to seal the unit.
Slowly turn on water to the filter by using the
by-pass valve.
remove trapped air.
Open any downstream faucet and allow filter
system to flush for 5 minutes.
Posted on Jul 10, 2010
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
GE Smart Water under sink dual water filters replaced. Very little water pressure. I have reinstalled them, no improvement. I have been replacing these filters for 5 years and have not encounerted this...
Hi jbboggeri,
Welcome to fixya!
I would go ahead and open the new set and install them. If you get pressure, you know the others were bad and can send them back for a refund.
If there is no change, you can always put them away and use them again later.
Please reply back and let me know how it went. Thanks,
Handie Andie
Jun 16, 2011 | General Electric GE SmartWater Household...
I need a handle for the Smart Water System
Here is the web page for GE. You will probably have to replace the whole faucet. When you call have the model # available for your system so they can supply the appropriate faucet. You may as well order more filters as they will be less expensive ordering on-line. These filters should really be changed every 6 months.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Dual_and_Single_Stage_Water_Filtration
These faucets are relatively easy to replace for the do it yourselfer.
RJ
Feb 24, 2011 | General Electric GE SmartWater Household...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
How do you change the GE smart water filters?
This page might help with changing it, as different models vary.
Feb 18, 2010 | General Electric GE SmartWater Household...
Instruction manual for ge smart water filter
Here is the website that you can get your users manual. You will need the model #. Pls rate ny answer
Kurt
http://www.geappliances.com/service_and_support/literature/
Apr 19, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
76 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
