Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
  • 52 Answers
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Posted on Jul 13, 2010
  • Thad Theall
    Thad Theall Aug 05, 2010
    Not unless its leaking.
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
I had to replace my pump motor and can't get my pump to quit leaking at the joint. I am trying RTV Sealer as we speak.
Did you change the seals? Whenever pump motors are replaced, the ceramic shaft (mechanical) seal should be replaced. Its also a good idea to replace the seal plate and diffuser seals.
May 29, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Punp leaking water think around barrins
You need to change your pump seal. It goes on the shaft of the motor as it enters the rear housing of the pump. If it has been leaking for a while,and started to get really loud you might want to replace the motor while you got it apart.
Apr 03, 2009 | Sta Rite Sta-Rite Super Max In-Ground 1.5...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
231 people viewed this question
Top Sta Rite Garden Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
