Question about RCA R52WM24 52" HDTV Projection Television
I can not get colors to converge the option does not come up in the menu
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
Picture is going out and colors all running togeather
That sounds like a convergence issue I would check the setup menu and see if the auto convergence option is stll listed under the setup menu options or hasit disappeared? Let me know and i will assist you with the issue
Feb 03, 2013 | RCA HD52W56 52" Rear Projection HDTV
Accessing Service menu to fix convergence
How far off are the colors misaligned such that you need to enter the service mode to fox them? If one or more of your colors has taken a dramatic shift in position, especially on any edge, then do not attempt to correct through the menu. If one of your convergence IC's has failed then the colors will not align on the screen. If you try to correct this in the menu, you will only be screwing up all the settings and making the set worse. When the IC is replaced with a new one your colors will still be way off, not because the new IC is not working, but because now the menu settings are too far off. I have been to many houses and spent 45 minutes replacing a burned out convergence IC followed by more than an hour realigning everything the customer messed up.
Aug 18, 2007 | Mitsubishi WS-55809 55" Rear Projection...
The color has changed so that grass looks like burned out fields and flesh tones look sickly. the menu color options do not seem to do anything, and blues still look fine. help! Baseball games look...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems
Jun 25, 2011 | Televison & Video
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
The color green has come out of the other colors
Needs to be converged if this is a projection tv. Check menu for a cutomer convergence option. Should be a manual or auto convergence. If you cannot move anything in manual convergence then convergence amplifiers are bad and need to be replaced. Professional can replace no problem.
Apr 09, 2009 | Televison & Video
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Red, green and blue color resolution
Hello my name is willie and i see this problem alot here at the shop. The symptons you describe is known as "convergence". OK your problem might have a simple soultion. if you can answer this question. When you acess the customer menu go into setup option.. then do you have convergence option. If you do not it will be known as the fl231 fuse. a fuse that common to blow due to bad connections. Now if you do have this option then you will have more problems with other boards. and it will have to be troubleshoot further. Does the picture also bown in at the top and bottom. when you go into convergence option(if you have it) does the cross hair move? let me know and i will see if i can help further
Sep 01, 2008 | RCA R52WH73 Projection Television
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
Press the CURSOR RING
RIGHT
to enter the PICTURE menu.
DOWN
repeatedly until CONVERGENCE
is selected.
RIGHT
to enter the CONVERGENCE
menu.
RIGHT
to enter CONVERGE RED
mode.
LEFT, RIGHT, UP, or DOWN
to
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Aug 21, 2008 | Philips 60P8341 60" Rear Projection...
Adjusting the convergance
On my 55 inch rear projection Samsung, there is a menu option to adjust the convergence. There is a manual as well as an automatic option. It is easier to do with the remote control. My Samsung remote has a button called 'perfect convergence' or something like that. you can also get to it from the menu tree pushing the menu button on the front of the set. You need to scroll through all the options to adjust color, contrast, parental control, etc. You should find it.
I assume the same is true on the 37inch samsung.
How old is the set? A number of samusng sets have problems with two large IC's that tend to burn out. This causes the symptom of colored shaddows, tend to be worse the further away from the center of the screen. I just finished doing the repair to my set. If you cannot adjust the convergence, that is most likely your problem.
May 13, 2008 | Samsung HCN473W 47" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
