Question about Black & Decker DW682K Dewalt Plate Joiner
How to change blade in dewalt dw682k I have the base plate off and I've figured out the spindle lock, the the ring with the two holes I can't make it budge. I created a jig with two #10 screws and a piece of plywood to turn it but it doesn't turn. What's the trick?
2 Suggested Answers
  • 145 Answers
SOURCE: Loooking for a Dewalt DW682K user manual for
DID YOU CALL THEM GOOD LOCK
Posted on Jan 08, 2010
How to remove four blade base plate from masport 450 series
use hole where bolt for blade goes insert a large screwdriver or steel rod and get it to catch on the casting or at the grass throw end with base locked you can now undo lock nut. should be lefty loosy.
Feb 26, 2017 | Cars & Trucks
Need to see how to change a blade please
make sure the saw is disconnected from the power point
place a screw driver in the teeth of the saw and turn it back until it locks against the base plate ( some blades have a hole in the blade through which a pin can be placed )
undo the spindle nut
replace the blade and do the nut up tight
Jan 09, 2016 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
I have a Black and Decker KS555 circular saw and
It appears that you have adaptors for the blades that are the same thickness as the blades Place the adaptor in the centre and then put on the spindle and tighten up the plates onto the blade.
Sep 05, 2013 | Black & Decker Tools & Hardware - Others
I can't figure out how to change the blade.From some of the other comments I've read , a lot of other people have had that same problem. So, how do I do it?
UNPLUG tool, remove the throat plate (piece that goes around blade) there are 2 wrenches that were supplied with the tool when new. One fits on the flats on the spindle and the other fits on the hex nut, what I generally do is brace the spindle wrench on the table of the tool and then with the hex wrench pull to loosen. You might have to TAP it with a small hammer to loosen, WEAR gloves when doing this to save scrapes on the hands. Let me know if you need more assistance.
May 24, 2011 | Bosch 4000 Factory Reconditioned 10"...
No manual and am not sure how to adj the depth
Hello there. There are 3 different models for this. Please click the link below to find the Manual for you specfic model.
Manuals
Hope this helps!
Zeppelinx12
Feb 24, 2011 | Black & Decker DW682K Dewalt Plate Joiner
How do I change blade
Make sure the saw is unplugged. Raise the arm to the upper postions and raise the blade guard by loosening but not removing the guard screw. Depress the spindle lock button and use the provided wrench to loosen the blade screw.
A full discription, with illustrations can be found on pg 6 of the user manual. In case you have misplaced the manual here is a link to the pdf from Dewalt.
http://www.dewalt.com/FAQs.aspx
click on obtain parts lists and manuals, click the highlighted ServiceNet link and enter your model number. Click the pdf icon next to manual and open the document.
Dec 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Is there a 2" blade available for the DeWalt Biscuit Joiner
Because of standardized sizes of biscuits, the only blade you can and should use, is the same size that comes with the tool. Anything smaller will not create the right diameter groove for the biscuits to fit properly.
Feb 16, 2010 | Black & Decker DW682K Dewalt Plate Joiner
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Black & Decker DW682K Dewalt Plate Joiner Logo
125 people viewed this question
Top Black & Decker Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Black & Decker Masonry Tool Expert? Answer questions, earn points and help others
