At the right side of my dell there is a clear bright green line vertically down the screen i dont know why it just apperaed one day
    President:
  • 2,571 Answers
You may be lucky and its just a loose connection.
You will need to remove the frame on your lid(around the screen) and reconnect the ribbon cable where it attaches to the motherboard.
If its a faulty screen you will need to decide if its worth fixing. screen are about £90
Posted on Jul 10, 2010
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have green arched =lines r=going through my screen How do I fix this?
If the lines are slanted up from left to right and spaced several inches apart, you are seeing the vertical retrace line. In that case, you may want to turn down the screen voltage on the green CRT. The instructions for making this adjustment are given in the service manual.
It should take just a small tweak to hide the retrace line. If adjusting the screen voltage won't do the job, check for a leaky or improperly biased CRT driver transistor, then compare the video waveforms with one of the other CRTs to make sure the voltage at the vertical blanking interval is correct.
In the worst case, there is a problem with the CRT. This is generally accompanied by occasional arcing (bright green flash or the set shuts down with an error code flashing on the power light).
Dec 05, 2010 | Sony KP-51WS500 51" Rear Projection...
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Dell E207WFP monitor
.Bad news.It cant be fixed.Try to take it back to the shop and get a replacement one.It might work for a few months or so but it is certainly a faulty screen.
Jul 21, 2009 | Dell D1028L 17" CRT Monitor
I have a clear bright green vertical line on my laptop screen
This sounds like the LCD inverter it could be getting ready to go, usually you will start seeing flickers as well, it may just be a faulty connection in the LCD either way, it's best to have someone look at it before the display goes all together.
Hope this helps
Dec 05, 2008 | Toshiba Satellite P30 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
LG Plasma TV MOdel 50PC5DC
You will definately want to call LG and have them refer you to an auth. service center for warranty repair. This is either a failed scan bd or mayber even a bad plasma panel and there is nothing simple for a problem as you describe.
Apr 08, 2008 | LG 42PC3D 42 in. Plasma Television
Computers & Internet Logo
David Payne
David Payne
