Question about AudioSource SW-15 Subwoofer
Installation instructions? i bought an sw 15 used.. and i'm kind of lost when it comes to home audio.. not sure how to hook it up.. there's alot going on back i run my wires from stereo to hi level in on sub then from hi level out to speakers? then there's the zero/180 switch and the the crossover frequency selector.. i'm sure this is all covered in the idiot pages in the front of manual but i don't have one of those:)
  • AudioSource Master
  • 18,309 Answers
Here is the manual. All pretty straight forward when written and in pictures.
Posted on Jul 30, 2017
2 Suggested Answers
  • 8546 Answers
SOURCE: hook up lower level input
The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
What is your electronics? Have you looked at the manuals?
Posted on May 03, 2011
Hunter fan light switch won't turn off light
by looking at the sw. it looks like u can only put it to a low dim and not off and the button at the bottom is all off including the fan if this is correct u should be able to change to a different kind of fan sw. combo or even a remote style that comes with a receiver ,also your fan should have three wires at the box a light wire "blue" a fan wire "black" and a neutral "white" oh and a ground "green" in order to switch these separate u need those 3 wires at the sw. also . but with a remote u only need the hot and neutral it hooks up in the box or canopy of the fan to the receiver all wires are marked for easy installation turn power off to be safe u can install a regular sw. to over ride the remote and turn power off at the fan .......its alot i know but hit me up if u need more help.
Mercedes Parts
May 25, 2012 | Hunter Ceiling Fan Light Switch Control
I have bought a Sony BDP-S380 Blu-Ray Disc Player. I have read the scanty instructions for hooking it up to my home entertainment system but still am unclear how to do it, which connection jacks to use...
Without knowing what your Home Entertainment System or TV capabilities are...
Page 10 of the not-so-scanty instructions lists the various video hook-ups to your TV in descending order or quality...
Here's how I would do it.
HDMI from the BD to the TV.
Digital audio (standard RCA cable) from the BD to the 'system'.
The best video goes to the TV without hops and extra expensive cable. The best audio goes to the sound system on the cheapest cable which can also be spliced for added length.
I never run either audio or video anywhere it isn't needed or enhanced.
Mar 20, 2011 | Audio Players & Recorders
I just installed a Denon 1610 A/V. I used my speakers from a older Sony 5.1 channel home theater system (DAV-S300). I got all the speakers to work except for the subwoffer. In order to hook-up the SW, I...
If you go to Manual setup/ select speaker setup/ select bass setting/ does it show LFE? If it does it is sending to main speakers only and you'll need to change to LFE+Main.
Oct 20, 2009 | JBL SCS135 System
Whenever i try to open my creative audio drivers (DELL XPS 1330)
well there's your problem right vista HOME!! it has soo many issues with it!!!
it sounds like it dosen't detect the hardware there are you sure that's what the laptop is using as its sound and are you sure its not conflicting with any other hardware?? if yes then i would try re-installing the software that came with may just have lost some files or could have been corrupted..and it should spring back to life
and please get rid of that home edition!!
before you have alot more problems!!
hope this helps,ben
Aug 13, 2009 | Dell XPS M1330 Notebook
MP3 not coming on
you can buy a charger at walmart for 15 dollars that hooks to all kinds of mp3 players (including the zen, which I use it for) and it charges in the car.
Jul 08, 2009 | Creative Labs Zen Touch MP3 Player
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
AudioSource SW-15 Subwoofer Logo
Top AudioSource Audio Players & Recorders Experts
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
