Question about Whirlpool Dryers
Dryee - one of the nlylon "flufers" came off the drum, looks like the 3 serews came off how do I re attached it?
  • 348 Answers
You may have to take off the rear or front panel depending on the model. Then you will be able to get to the drum to reattach the baffel. Or if you don't want to remove the panels you can use a good epoxy glue that stands up to heat and simply glue it back from inside the drum. Back that up with short sheet metal screws and make new screw holes for a good fastening. Good luck.
Posted on Jul 11, 2010
Accelerator cable
hello azhar..just remove the wire connector that attached to the carburetor.......
Jan 27, 2014 | Hero Honda Motorcycles
Clothes getting caught in Kenmore dryer
The bearings under the drum may have failed, making the drum drop, so the gap is bigger. Replacing drum or bearings is a lot of work, cheaper to replace the dryer. Or you could make a plastic ring yourself that is thicker to fill the gap....
Dec 27, 2013 | Dryers
Hi. I have a Bosch precision wfg 2820 front load washing machine. The drum no longer spins round. The belt is still attached and seems to be ok. Any ideas where to look next? Thanks
You say seems to be ok.....can you hold the belt and turn the drum? Is there more that 3/4" slack in belt when you push it side ways? How old is this machine and have you ever had it serviced?
Jan 03, 2011 | Washing Machines
I am assembling the Wiggles Rock n' Roll drum kit. I have attached the cymbal and foot pedal, but cannot work out how to attach the two tom toms to the bass drum. There doesn't seem to be a logical...
If you look at the plastic sides just near the joins there are holes punched that you need to push out and the screw goes through these and attaches to the large drum at the metal anchor points
Dec 26, 2010 | Toys
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
How to replace fuser unit
Hello,go to back side of printer & open the flap u will found two serews open them push the tray & open the two locks at right & left bottom then back pannel will come out.pullout the white strip where the power connector inserted you will find fuser connector (black,white wires)open 4 screws on which fuser wire attached detach two connectors situated right side wall of printer& you will find a teeth lock on the bottom side of fuser press the two leavers & pull outwardly & also pull out the unit outwardly & do as viseversa for fixing the unit.
Oct 08, 2010 | HP LaserJet P3005n Printer
98 Ford Escort, Emergency brake doesn't hold car. Rear brakes okay, adjusted cable to 3 clicks. What am I looking for?
If you have rear rotors that look like a rotor mounted on top of a drum brake, you will have an emergency brake inside the drum portion. The rear brake rotors are not flat like the front rotors for this style.
The E brakes have brake shoes and they have "Star" wheels for adjustment just like the regular drum brake. You really need to take off the rear rotors to inspect the inner drum portion. If you do adjust the E brakes without looking at the drum part, chances are the drum is pitted and rusty and you will be lucky to stop once before the E brake linings are ground off.
The other type of E brake works off the Rotor pads. You will see the brake cable attached to a lever on each wheel. There will be an Equalizing cable connecting both rear wheels with an adjustment point joining the main cable. Although the 3 clicks moves the main cable, to have both rear brakes equally tight you need the Equalizing properly adjusted.
Those are the things you need to look for.
Jun 15, 2010 | 1998 Ford Escort
Plastic things inside the drum have all come off,
If they have come off, it is because they are worn or broken.You need to fit 3 new ones
They are referred to as drum or clothes lifters, thier purpose being to move the clothes around.
Do not use the washer until you have got them fitted.
They usually slide and click into the slots in the drum.
Mar 01, 2010 | Indesit Washing Machines
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ratalantis washer/dryee
Unfortunately not. The extended warranty is only offered when you purchase the machine and is an extension of your normal warranty which has obviously expired.
Oct 09, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
