Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Where is the fuse on the robokleen above ground pool cleaner? We've only had ours for 1 year and it stopped working. It doesn't come on at all. At first it would come on and just move back and forth in the same spot. Now it doesn't come on at all.
We have had our for about 5 years with no problems til now. Our cord broke on the inside, meaning the wire inside broke from taking it out of the pool by the cord. I just opened it up, cut the wires, put heat shrink on the cord, butt spliced back together and placed heat shrink over the splice. Also there is a fuse and it is located inside the power box. Unplug unit remove screws from back and fuse will be right there, 1.6 amp I think.
Posted on Aug 04, 2010
  • 52 Answers
There is an online manuel at this address http://74.84.137.218/website/manuals/RK01A.pdf
There is a circuit board that needs to be reset and the manuel discribes how to do this process. Make sure you are using a ground fault outlet to plug into. If there is a fuse, but I don't think there is it would be inline on the power cord. Also check the Breaker box to make sure there is power to the recepticle.
The Pool Tech
Posted on Jul 10, 2010
My bug worked great last season but this year I will find it stopped in the pool not moving, I will pick it up and push on the feet to get them running again and it will stop again, what do I need to
It may be that you have one of several possible problems that could be the reason for the symptom you are experiencing:
  • Low water flow thru circulation system
    • Dirty Filter
    • Baskets filled with debris
    • Clogged Pump Impeller
    • Clogged suction line between suction port and actual cleaner
    • Clogged/plugged cleaning unit itself
  • Worn gear assembly within the LadyBug
Jun 12, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
My robokleen won't **** anything up, impeller not plugged or stuck, just not turning, moves just fine
i thought the problem was the grease also until i seen another sales web page decription, it said NO OIL TO LEAK OUT, so i opened it up again after it shut off every day for 10 minutes of use , but still rolled
i seen the circuit board inside the air tight pump, somehow some water must have mixed with the greased part and i dried it with a cloth put it back together and it ran for about 20 minutes, then stopped, i tightend the screws as much as i could without harming the thread holes, if you break them your out of luck, did not see any seal but im sure the factory put something to keep it water proof
Jun 11, 2012 | Smartpool Dolphin Robo - Kleen Above...
Hi! My RoboKleen is running and moving, but not vacuuming. Do I need to check the impeller? If so, how do I do that? My manual doesn't have a parts diagram. Jane
I would check the impeller for obstructions. To check it, remove the top grill off by removing the 2 screws from the top. Make sure the transformer is unplugged first. You should see the impeller when you remove the grill. Remove any debris and just put the pool cleaners grill back into place and rescrew. I would also empty your debris bag. It could be filled and causing a lack of suction. Check for debris in the cleaners throat.
Jun 10, 2011 | Smartpool Dolphin Robo - Kleen Above...
Robokleen is now making very short back and forth motions not covering the entire pool as it did when first purchased
First, check the impeller for obstructions. Occasionally hair or linen may get caught in the impeller. With the transformer off, take the top grill off by removing the 2 screws from the top. If you see any debris caught, remove it and replace the grill and screws. Also, check the pool cleaners axle bearings and wheels for leaves or other debris that could be causing the wheels to catch. If you can solve the problem with either of these, you will probably have to have the cleaner services because it is going to be a mechanical issue and you will void your warranty if you open the electrical components of the cleaner.
May 13, 2011 | Smartpool Dolphin Robo - Kleen Above...
Our dirt devil pool cleaner keeps sticking to the pool floor and will not move around, what do we need to do?
Make sure that your unifram is installed with the opening in a vertical position. If it is horizontal, you pool cleaners line will not have proper suction. You will also want to check for obstructions in the flapper that would cause the cleaner to not move properly. Finally, make sure that this is the proper cleaner for your pool size. If you have an in ground or very large above ground pool, it is possible that the pump you are operating with is too strong for the cleaner to move properly.
Apr 09, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
My robokleen vac runs for a few minutes then just stops. I checked the wheels nothing is stuck in there. Any suggestions?
With these pool cleaners, there are several things that you should check. Make sure that your filter bag is not full and does not have any large debris that would hinder movement. Make sure that your impeller is not jammed or broken and check the entire drive system for objects that might have become lodged.
Aug 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
Robokleen stays in same spot going back and forth about four feet wont go around pool it was stuck the other day on a pool toy and couldnt get off of it we didnt know about it til we pulled it out later...
With these automatic pool cleaners, a jammed impeller can cause it to not work. Since the cleaner was caught on a pool toy, my guess is that it has some fabric/material jammed in the impeller and that is causing your problems. Open it up and check your impeller. I am sure that you will find it jammed.
Jul 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
My automatic robokleener will move for a few seconds and then stop what could this be?
Check your impeller. Often on these automatic pool cleaners, the impeller can become jammed and make movement impossible. Also, check your front and rear axles to make sure that you don't have any obstructions there.
Jun 21, 2010 | Smartpool Dolphin Robo - Kleen Above...
My robokleen is going back and forth what is wrong?
I would first check the wheels and axles bearings for hair, leaves, lint, or other debris that might be causing your pool cleaners wheels to have restricted movement. You might also want to try removing the limit screw on the wheels to see if that helps. Also, make sure that the impeller is not jammed. Remove the grill cover, check the impeller, and replace the cover. It could also be an electrical issue also. If this is the case, do not attempt to repair it. Go to SmartPool's website and find a repair service in your area.
Jun 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
629 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
