Question about Sega Game Gear Console
The game gear won't turn on
The power light will not turn on when i put batteries in the battery port
2 Suggested Answers
humanman42
  • 82 Answers
SOURCE: I have several game gears and battery packs with problems
The battery compartments were notorious for getting broke. I have fixed a couple. The contacts would get rusty and sometimes harm the mainboard. go to www.benheck.com and look on there forums. They will probably have detailed instructions there.
Posted on Dec 02, 2008
I found this Game Gear at a thrift shop, and i put in new batteries but it won't turn on. Why?
Make sure the connections were the batteries hit on each side on the game gear..are not corroded..or rusty.take a piece of sand paper to them ..to be sure..also try other batteries.. if still no power up. Would be the switch..
Jul 27, 2014 | Sega Game Gear Console
Car Won't Work. HELP!!!
did you check battery could be death.Gas pedal is moving,under steering wheel any wires damaged.It is full park position.
Apr 30, 2013 | 2002 Pontiac Grand Prix
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Board power flashes then turns off
i have put in new batteries in my wii board and the lights turn off please help
Jan 02, 2010 | Nintendo Wii Fit - Balance Board + Game...
My husband turned off our Chevy Trailblazer without putting it in gear and now it won''t start and the gear shift is lock up. What do you do to fix it????
first make sure battery isn't dead because if he cut it off in gear then the switch couldn't cut the power off and it'll run the battery down and there is a electrical solenoid that allows the shifter to move if theres no voltage than the shifter want go into park and the ignition switch want turn off.
Dec 27, 2009 | 2005 Chevrolet TrailBlazer
Dont know how to use the system
Sega Game Gears are notorious for having the battery compartments rust and break because of prolonged exposure to batteries. So check that. Then put in batteries and see if the light turns on. If all checks out. Put in a game. No video. Take the game out, put it back in a dozen times. That will strip down the contacts a little it to help make a good connection (works well on NES's too, well most systems with cartridges). Still nothing, try another game. Or clean all the contacts with some sort of alcohol. Like rubbing alcohol, or fingernail polish remover. I have a GameGear also and I went though what you are going through. What I told you to do made mine work. Good luck!
Dec 02, 2008 | Sega Game Gear Console
Sega Game Gear Console Logo
263 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
