Question about Champion 2000+ Household Juice Extractor
Champion juicer will not start. Switch seems fine. Replaced capacitor, but still no response, no buzz, or anything. The motor turn easily by hand, so there are no obstuctions. The juicer worked fine, I was using it for the past 3 months; then suddenly, for no apparent reason, it just doesn't work.
  • 3 Answers
SOURCE: Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Posted on Aug 16, 2007
  • 69 Answers
SOURCE: cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Posted on Feb 07, 2009
  • 69 Answers
SOURCE: Champion G5NG853S Household Juice Extractor
Juicer has to be attached, little magnet on the bottom.
Posted on Mar 01, 2009
  • 69 Answers
SOURCE: Champion juicer don't work
You have to have the juicer attached, there is a little magnet that allows the machine to turn on.
SOURCE: My champion juicer won't expell pulp propperly.
Use the tamper?
Posted on Nov 20, 2009
We just got a 2nd hand juicer CHAMPION model G5-NG-853S. Where can I find a manual for it.
The CHAMPION juicer manual is online at: http://www.discountjuicers.org/manuals/champion.pdf
If your juicer needs parts or maintenance, the phone support is easy to work with - call them directly at:
(209) 369-2154
Jul 26, 2011 | Champion G5NG853S Household Juice...
Can't find a supplier of a capacitor for my Champion juicer tried loads of sites including the main producer
go to wwgrainger.com the capacitor # is 2MDT3 made by dayton,its a bit longer(dimensions are (3&3/8" High X 1&7/16" Round) but there should be room they have store all over the nation
Jul 05, 2010 | Champion G5NG853S Household Juice...
Champion juicer developed a high pitched squeal
Champion Juicer manufacturer has an oil refill for 5 or 6 dollars. I just ordered one and I expect that should solve the problem.
Apr 29, 2009 | Champion G5NG853S Household Juice...
Juicer does not work.
Had same problem...juicer stop working without any warning. First I took the unit apart and remove the on-off switch and capacitor and had them tested by appliance shop. Both checked good. Next I remove the small circuit board behind the face plate below the motor shaft; circuit board was coated with oil and shaft grease. Appliance shop did not know how to test it, so I clean it all up and reassemble the unit. I told God is it worked I would praise Him. Hallelujah to God ... it worked. I hope my experience helps someone. God is good.
Jul 18, 2008 | Champion 2000+ Household Juice Extractor
Replace Body/Hub Combo
After reading your initial post and responding...yes, take a 1/4" socket wrench and loosen the four bolts at the other end of the motor. The hub will come off easily. If you have ot replace the oil seal, I have not figured out how to do that yet. I beleive the replacement hub has a new oil seal already installed. hope this helps
May 16, 2008 | Champion 2000+ Household Juice Extractor
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
Jan 09, 2008 | Champion G5NG853S Household Juice...
Cutter
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
Champion Juicer stopped working
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Champion 2000+ Household Juice Extractor Logo
73 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
