Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
My poulan gas weed eater won't start. It has gas.
  • 63 Answers
Check spark plug and H T lead then the air filter
Posted on Jul 24, 2010
You may want to take it down to access the muffler, remove it and check for carbon build up on the block where the piston is visible. My Poulan leaf blower quit working one day and refused to start, even with a new spark plug and fresh 40:1 mix ratio gas. I decided to take it down completely and discovered my exhaust port was nearly blocked all the way. I removed the carbon, regapped my spark plug to 0.025, and cleaned the magnets on the fly wheel and ignition module. Once put back together, it started up on the third pull and ran like new. Forgot to mention I took apart the carburetor completely and cleaned it.
Posted on Aug 25, 2012
2 Suggested Answers
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Eng wont start, plug chngd, gas check good
could be lack of compression they won;t start with 60lbs
check if head bolted on tight
Nov 15, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
GBI 20 Weed Eater Blower ran out of gas and will not restart What to do to restart?
somewhere on it is a primer button pump it a few times and choke the blower it should start
Sep 18, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
1,236 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
