Question about Video Game Consoles & Games
When trying to load a new franchise on ps2 madden 06 I see please wait after I choose my team. I've left home and came back and the screen still says please wait.
    Guru:
  • 528 Answers
Hi. We have two isue here. One is the gam that you are trying to play is having a problem. You may try inserting the DVD game to another PS2 and check if you will be getting the same issue. If same issue occurs then this could be a DVD game problem. Second is, it could be your PS2 is having a problem. PS2 lens is having difficulty reading the DVD game. Possible it requires cleaning. You can also try putting another DVD game to your PS2 and check if it will hangs.
Posted on Jul 12, 2010
  • 16 more comments
  • Archie Cruz
    Archie Cruz Jul 12, 2010
    any feedback here?
  • chatman4 Jul 12, 2010
    It is probably the lens. I bought another copy of Madden and got the same problem. How do I clean the lens?
  • Archie Cruz
    Archie Cruz Jul 13, 2010
    Hi. Yeah this could be a lens problem. i have this issue with my PS2 before. I provided you a video from youtube on how to clean your PS2 lens. Please click here.
    All the best!
  • chatman4 Jul 13, 2010
    Thanks. I tried this. I believe that I may have unplugged my controller while attempting to load a new season. Could this be the problem. No other DVD or game freezes.
  • Archie Cruz
    Ok Good. Just dont forget to rate my answer so that i will know i can help people with their technical problem.
    Have a great day.
    I will, but, the problem still persists. I've cleaned the lens and every dvd/game works fine including Madden 06. The only problem is that I cannot load Franchise mode on Madden 06. I've bought another copy of the game and still have the same problem. When I start franchise mode, please wait comes up on the screen, the music stops, and the disc stops spinning.
  • Archie Cruz
    have you tried loading the game with other PS2 unit? If you will play other game from your PS2 aside from madden are you getting the same problem (screen hangs).
    The screen does not hang with any other game. And it only hangs while trying to load the Franchise mode in Madden
  • Archie Cruz
    Archie Cruz Jul 14, 2010
    have you tried running the game with other PS2?
  • chatman4 Jul 15, 2010
    No I haven't. I was trying not to buy a new PS2
  • Archie Cruz
    Archie Cruz Jul 15, 2010
    I mean if you have a friend who happens to have a PS2 try to test the DVD game to his PS2 if it will do the same thing. Or you can go to a Shop where they sell PS2 and act as if you are interested of buying a PS2 and ask the seller to test your game DVD then once you test it walk out and tell to the seller you will come back again. Sounds like a plan huh!
  • chatman4 Jul 16, 2010
    I like that. It may be a day or two.
  • Archie Cruz
    Archie Cruz Jul 17, 2010
    any update on this?
  • chatman4 Jul 17, 2010
    I just finished cleaning my lens with alcohol and a q-tip. Waiting for it to dry and then I will try. It's just strange that everything else in the game works fine. When I go to franchise mode and choose my team, please wait comes on the screen and it pauses.
  • Archie Cruz
    Archie Cruz Jul 18, 2010
    It could be a glitch on the game. By the way, have you tried playing this game with other PS2?
  • chatman4 Jul 18, 2010
    no access to another ps2.
  • Archie Cruz
    Archie Cruz Jul 20, 2010
    any feedback to your testing?
  • chatman4 Jul 20, 2010
    no feedback I took my ps2 apart and cleaned the lens and still the same issue. I also bought another copy of Madden 06 and still the same issue. I removed my memory card and tried to load it and still got the same issue.
    Guru:
  • 468 Answers
I am not pretty sure about it but I suggest you to d a power drain i.e unplug the battrey and power cable from the unit and hold the power button for 20 secs. It will drain the static from the unit. Now, connect the battrey & power cable. Try to add franchise. You can also visit the below mentioned link:
http://www.easportsworld.com/en_US/madden/franchise/franchises
Posted on Jul 11, 2010
  • 5 more comments
  • Balakrishnan Computers (A Computer Repair Shop)
    what excatly happens after performing the above stepps.
    http://www.easportsworld.com/en_US/madde...
    After unplugging all cables and holding the power button, the game loads and it freezes when I try to start a franchise. Exact same issue. I do not know how to disconnect the battery on my system.
    On the back on the PS2 there should be a flap that opens like in Cell phone or Laptop. Remove that flap and check if you are able to see the battrey. If not tryo turning Off the unit & restart it, then try to load a Franchise.
    Try this too:
    Before you play any game you should reboot. DO NOT eject Madden out of the ps2, leave it in but turn the ps2 off, then turn it back on load up madden. load up your franchise and train your players before the game then you play. After you finish your game you should save it.
    Also, if u have had your system on for awhile before either playing madden or another game, my advice is to reboot before u play ur franchise game.
    Try this too:
  • 1,284 Answers
Hi, there are two ways to this problem. It's either you have a weak lens in the ps2 which will definitely not play the game until you replace it or that you have a faulty cd. Try changing the cd and if the problem persist after changing the cd, then you have a bad lens.
Take care
Posted on Jul 10, 2010
  • 3 more comments
  • chatman4 Jul 10, 2010
    This only happens when I load franchise mode. I can play whenever, i just cannot start a franchise. Wouldn't it affect every game and every mode of the game if it were the lens?
  • Shehu Pro
    Shehu Pro Jul 10, 2010
    Then there is something wrong with the franchise mode, try changing the cd
  • Shehu Pro
    Shehu Pro Jul 11, 2010
  • chatman4 Jul 11, 2010
    This is my second copy of Madden 06
  • Shehu Pro
    Shehu Pro Jul 12, 2010
    o.k, will get to the root of the problem soonest.
What are the cheats for madden nfl10 for ps2
TEAMPLAYER: Franchise Mode
THEWORKS: Master Code (Unlocks Everything)
YOUCALLIT: Situation Mode
EGOBOOST: Superstar Mode
ALLSTARS: Unlocks Pro Bowl Stadium
THEBIGSHOW: Unlocks Super Bowl Stadium
May 21, 2012 | Electronic Arts PS2 Madden NFL 10
No data on memory card
the chances are is that that data has been corrupted wen your ps2 freaked out, and both the ps2's cant read it as corrupted data, so it chooses not 2 show it on-screen. sorry dude, but ur game data is lost
Aug 12, 2009 | Sony PlayStation 2 (PS2) Console
Madden 09 freezes when trying to save on PS2
try a new memory card or erase some that u dont use on the old one!
Mar 18, 2009 | Video Game Consoles & Games
Madden 2009 freezes between seasons in franchise mode
EA are working on a patch for both XBOX LIVE AND PSN. It is a known issue. propossed rollout for the patch is mid march im afraid
Feb 24, 2009 | Sony PlayStation 2 (PS2) Console
Madden 08 loading problem
This sounds like you guys have discovered a bug, or glitch ... whilst i know this is very annoying if you love your console and games as much as i do, you want a fast easy fix ... and you want it yesterday.
Due to the nature of your complaint, and the fact that one other person has discovered a similar problem with the same game, i would firstly contact the software developer ( the guys who made it ) and ask them for a fix or as we say "patch" to help iron out this problem.
Get online at easports and register and perhaps take a look at the forums.
http://www.easports.com/maddennfl/home.jsp
Games will always have glitches and bugs, ea have been around for ages so their support team should be "on the ball" with problems like this =)
Jan 21, 2008 | Sony Playstation 3 (PS3) Console
Madden 08 wont let me get past a game
go to the XBOX desktop and cleared all my Madden 08 history out and then everything started working great again. That really sucked though because 5 franchise years and probaly over 75 hours of time GONE. Thanks for the reply and the xbox site was on the right trac
Jan 14, 2008 | Microsoft Xbox 360 Console
Ps2 slim madden 08 lag?
yeah, that happens on mine sometimes. IT happens on both the ps2 regular and my madden 07 for psp. I thin it's probably just trying to do too much at once, and slows down because the processor isn't powerful enough.
Dec 16, 2007 | Sony PlayStation 2 Slimline Console
Video Game Consoles & Games Logo
89 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
