Question about Sony Handycam DCR-TRV510 Digital Camcorder
Is there a USB dubbing cable available for me to transfer video from tape to CD
    Sergeant:
    Champion:
  • 338 Answers
Yes the cable is a USB to USB large from camera to PC, available from Comet, Currys, Maplin, PC World, Jessops around £14.
Posted on Jul 11, 2010
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
What are the steps to dubbing off the other tape?
You need a set of RCA AV dubbing cables (available at fine electronics stores everywhere), and a couple VCRs. Plug the cables into the "A/V Out" jacks on the back of the VCR that will be playing, and into the "A/V In" jacks on the VCR that will record.
Also on the recording VCR, use a regular coaxial cable to attach it to a television.
Now, set the TV to 3, fire up the VCR's, and set the recording VCR's TV/VCR toggle to VCR. Also on the one that is recording, set the channel to "INPUT" or "AUX" or something like that. (You're telling it to record what it sees coming from the jacks you plugged the cables into.) Then hit Play on the other machine. You should be able to see your tape playing back. If you do, you have followed these directions correctly, and you're ready to make your dub.
HINT: The first few feet of tape are often prone to dropout and generally sucking. Record a minute of black before making your dub. Mark this on the tape or tell them when you turn it in. They will be impressed.
May 28, 2010 | Sony DTC-ZE700 Dual Cassette Deck
How do i go about transfering vhs-c video from an
You have several options. But important one to understand is the limitations of a PIII computer like Armada e500. You may not have enough grunt to convert stuff, even after buying the necessary video capture devices which work on USB.
Also I am assuming you either have the jvc camcorder still available or atleast have a VHS-C to VHS adapter to play the tapes on a standard VHS tape player.
Unless you are having a lot tapes and need editing while converting, your better bet might be to go to one of the shops that convert these tapes on to DVD or a suitable flash drive which might work out cheaper and quicker.
The last time I did this thing (quality of my VHS-C tapes was bad) I bought a Samsung combined VHS Video / DVD recorder and used the dubbing feature to burn DVDs. Cost me about $150 a year ago. I was able to do some editing on the way as I was connected to the TV screen as well. Saved me the hassles of dealling with the PC type video capture devices and software.
Dec 25, 2009 | JVC S-VHS Tapes (ST120SVDU2) S-VHS Tape
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Problems dubbing from hard drive to DVD RW disk
Switch CD R or DVD R
RW disks are not suitable for this work.
Dec 17, 2007 | Computers & Internet
JVC GR-DVP7EA: Transferring tape to PC via USB cable
Look in the manual which was supplied as part of the package when you purchased the camcorder.
Sep 12, 2017 | Video Cameras
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony Handycam DCR-TRV510 Digital Camcorder Logo
101 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
