Question about Remington Health & Beauty
MS2-390 SHAVER / TRIMMER... HOW DO I DISASSEMBLE THIS SHAVER TO USE THE OTHER SIDE OF THE TRIMMER?
  • 493 Answers
Hi
You can download the user manual from this link.
Hope this helps.
Posted on Jul 10, 2010
Brector3 provided a highly informative procedure for replacing R9500 shaver batteries. Can you please provide more detail on how to "disjoint" the trimmer to gain access to the third screw? ...
To access one of the screws on the back or the unit, the trimmer must be partially removed. When you pop up the trimmer for normal use, it pivots near the top of the shaver. At this pivot point, each side of the trimmer has a tiny plastic pin that inserts into a socket of the shaver body. You can insert smaill flat screwdriver between the side of the trimmer and the shaver body and gently pry the pins out of their sockets
May 07, 2011 | Health & Beauty
Can I replace the trimmer blades (not the shaver heads) on my Philips 8175XL? I use them all the time and they are wearing out. Where do I get them and how do I install them?
You will find a replacement trimmer at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-sideburn-trimmer-p-388.html
See disassembly video tutorial at shaveroutlet.com using the link below. You will not have to disassemble as far as the video shows. Just remove the back cover and the trimmer can be 'disjointed' from the cover
http://www.shaveroutlet.com/philips_norelco_shaver_disassembly
Oct 27, 2010 | Philips Norelco 8175XL Electric Shaver
Is the side blade working? if yes how?
push in the shaver on/off switch and push the trimmer all the way up until it is fully extended. the trimmer should work in this position
Jan 18, 2010 | Braun 8975 360 Complete Men's Shaver...
I just need to know where I can get new batteries for my braun syncro 7505. The batteries don't have any markings telling the volts or milliamps. I would greatly appreciate it if someone could help me with...
Yes, these are NiMH AA 1.2V flat top batteries. Replacements can be found on some battery websites (like onlybatteries.com). I'd get the 2200mAh rated ones, as they'll hold a longer charge than the 1650mAh ones. You will need two of them (the shaver has a 2.4V motor). This works for most Braun shaver models from 6000 to 8000.
Aug 15, 2009 | Braun Syncro 7526 Electric Shaver
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
8595 Pop-Up Trimmer Broken
http://www.electricshaverstore.com/get_item_7030247_braun-housing-silver-activator-type-5643.htm
This is the best solution I've found. (Found it thanks to another forum). Its the whole casing which includes the trimmer. Frankly, I'm not going to argue with the price.
The shaver itself is easy to take apart. The part on the bottom (opposite from the shaver mechanism) pops off with just a slight bit of prying. Be careful not to break the pins though. Once you have that off, the narrow sides pop off pretty easily. Then you can remove the 4 screws opening up the interior.
Be careful at this point because there are a lot of parts that may fall out. (Perhaps take a picture as soon as you open it so you know where everything was when you opened it). At this point you can try your hand at fixing it (mine had 3 parts broken and loose inside), or you can simply switch it with the new casing (Which i'm going to do when I get it). Good Luck!
Oct 28, 2008 | Braun Activator 8595 Electric Shaver
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Braun shaver 7505.
Greetings,
Need to replace the switch. If you have the skills to disassemble the unit, proceed. Otherwise replacing the shaver will cost you less than having it repaired.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 01, 2008 | Health & Beauty
Where do I buy a replacement side-burn trimmer for the shaver?
The trimmer is sold as the back housing assy. I have them in stock. Please call me aty 1-888-643-9806 to order 1. I will tell you how to get the shaver apart to replace. Ask for Action Mike.
Jun 05, 2008 | Braun 8585 Electric Shaver
Health & Beauty Logo
22 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
