Question about Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply
I need the accessory that allows me to recharge my Xantrex 300EP by plugging it into an AC wall socket. Where can they be purchased? Thanks Richard
  • 1,675 Answers
Hi you can get one from the link below..hope that helps
http://www.xantrex.com/index.asp
Posted on Jul 10, 2010
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
Xantrex power inverter 1750
The 14 AWG Positive wire should be connected to one side of a 30 A relay (typical fog lamp relay available at most automotive stores). The relay's other 30 A contact should be connected to the battery positive post via a 10 AWG (up to 6 ft/2 m)
Sep 07, 2008 | Xantrex Technology Xantrex Xpower 1750...
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
I have lost the ac adapter for my Xantrex Powerpack 200 Plus. Where can I get one for a reasonable price?
You need a 12 Volt AC/ 1 AMP (1000ma) charger. You can use one with a lower ma rating but it will take longer to charge. The factory unit will take 35 hours to fully recharge a totally discharged battery. If you use your car's cigarette lighter it will take 3 hours if you're charging and driving. Good Luck!
Aug 24, 2011 | Xantrex Technology XPower Powerpack 200...
MY GPS MAGELLAN IS SHOWING LOW BATTRIE, WHAT DO I DO TO FIX IT.
You should have received either an AC adapter or a USB cable with the unit to use for recharging your battery. The AC adapter would just plug into the wall socket and then into your unit. The USB cable would be connected to your computer while it was running and then the other end would fit the GPS. This will also charge your unit. If you do not have either of these cables you should be able to go to your local Best Buy, Circuit City, or even a Walmart, and you will be able to purchase at least a USB cable that will charge your unit. There are adapters out now that will plug into the wall and then plug into the USB port on the GPS for charging purposes.
May 15, 2011 | GPS
I have a Xantrex 2400-12 two years old, installed off grid in a vacation home in Mexico, a service call is not an option. The inverter quit working, flashes "888" and shuts off. I have a trace...
First off I am not in this for the money. If your not satisfied with the information below simply reject the solution so that you can hear from other experts.
The 888 flashing is telling you that the inverter has lost DC power momentarily. This can be from broken strands in the battery cables or an internal wiring problem in the inverter. Check the battery cables for corrosion. Remove the terminals check for battery post corrosion and visually inspect each bable to terminal connection from the battery connector to the inverter DC Power connections.
Here is something to keep in mind. A DC power cable only needs one tiny strand of wire to indicate voltage on a meter. However, if there is any load on the AC side that tiny strand of wire that is giving you the proper DC reading may in fact drop well below 10.5 V DC and simply cause the unit to automatically shut off even with no load.
Explain your situation to Xantrex using the link below and they may be able to help you due to the fact that you do not have a local "post warranty service provider" in Mexico:
If your product requires troubleshooting or warranty service, contact your
dealer.
If you are unable to contact your dealer, or the dealer is unable to provide
service, contact Xantrex directly at:
Direct returns may be performed according to the Xantrex Return Material
Authorization Policy described in your product manual. For some products,
Xantrex maintains a network of regional Authorized Service Centers. Call
Xantrex or check our website to see if your product can be repaired at one of
these facilities.
What proof of purchase is required? In any warranty claim, dated proof of
purchase must accompany the product and the product must not have been
disassembled or modified without prior written authorization by Xantrex.
Proof of purchase may be in any one of the following forms:
• The dated purchase receipt from the original purchase of the product at
point of sale to the end user, or
• The dated dealer invoice or purchase receipt showing original equipment
manufacturer (OEM) status, or
• The dated invoice or purchase receipt showing the product exchanged
under warranty
Telephone: 1 360-925-5097
Fax: 1 360-925-5143
Web: www.xantrex.com/support
customerservice@xantrex.com
The owner's guide is here:
http://www.xantrex.com/documents/Power-Inverters/Xantrex-Inverters-Digital/XPower_200-400-800_Digital(975-0176-01-01_Rev-B).pdf
Thanks for choosing FixYa,
Kelly
Jan 16, 2011 | Xantrex Technology Trace Series Inverter /...
No power or recharge light is there a fuse inside from wall to laptop tested 18.5 volts coming out but cant turn on recharge
Hi,If there power out from the ac power pack then the next area to check will be the socket going in to the machines,this leads me to the next point,
try removing the battery ,plug in the ac power pack,
if no result then it will be either the mother board or power socket,
sometimes cheaper to replace it unless you know what your doing,
Apr 30, 2010 | Computers & Internet
Poor FM reception with Altec Lansing IM600 when using ac adapter
here is what I recommend, and It may be irrelevant but it could work.
the ac adapter cable may be creating interference with the radio signal, so what you can do is go ahead and try connecting the ac adapter as far away as possible from the device in a way that the( keep the cable as far away from the device, just leaving the plug into the hole)
and try putting some antistatic tape onto the end that goes into the device.
good day
Dec 28, 2008 | Altec Lansing Inmotion-IM600...
Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply Logo
93 people viewed this question
Top Xantrex Technology Computers & Internet Experts
steve morris
steve morris
Rick Moore
Rick Moore
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
