Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
Lights go back and forth 2 or 3 times and then flach
    Novelist:
    Champion:
  • 232 Answers
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
Yellow light
Try soaking the blades with some lubricant and leaving for a while then try running in reverse it should solve the problem, youight need to repeat the process 2-3 times for the best results
Aug 19, 2013 | Compucessory CCS 60062 Shredder
Interior lights don't go on in Miele G5910 dishwasher
Cause 2:
The lighting was accidentally switched off (e.g. while refilling the rinse aid or salt). When the door is halfway open and quickly moved back and forth three times, the interior lighting is switched off.
Remedy 2:
Please open the dishwasher door halfway and quickly swing it back and forth three times. When doing this, open the door wide enough so that the internal lighting is switched on and off. The interior lighting is now permanently activated.
Dec 24, 2012 | Dishwashers
Check engine light just came on 1993 toy camry
First you need to find out what the fault code is that is making the check engine light come on. To do this, locate the diagnostic connector under the hood. It will be a black rectangular connector approx 50mm X 25mm with Diagnostic written on the cover. Open the cover and on the inside of the cover will be a diagram of the connections and their different labels. Locate pins labelled TE1 and E1. Switch on the ignition switch without starting the engine and with a small jumper wire bridge between pin TE1 and pin E1. Observe the check engine light on the dash and you will notice that it will be flashing. Read the diagnosis code as indicated by the number of flashes that this light makes. Each code will be displayed by first blinking the first digit of the code, then a pause and blink the second digit of the code. For example, Code 52 (knock sensor signal) will flash 5 times, pause and then flash 2 times, then a longer pause before it goes onto the next fault code if there is another one. Once it has gone through all the stored fault codes it will go through the sequence again starting at the first fault code again. Due to the many different fault codes that can be obtained it would be better to post another question for the fault code obtained. Good luck!
Jan 06, 2010 | 1993 Toyota Camry V6
My ps2 slim lens move foward and makes wierd and unusual noises it also doesn't even read any dvds
turn it on wait wen it makes de noise for a minute but wit no disc then open it move the lens back and forth very lightly if you do it to fast the ps2 might not read for a day or 2 when ur done moving the lens back and forth intel it don't move lightly any more then try a disc if it don't work do this process intel it works but wait 5 min before you do it again so the ps2 won't reck for half a day before you turn the ps2 off to do the process ithhis works for me 1st or 2nd times
Mar 14, 2009 | Sony PlayStation 2 Slimline Console
Won't work
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
May 23, 2008 | RCA RCR412C Remote Control
Help!
May 03, 2008 | RCA RCR412C Remote Control
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
53 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
