Question about Soyo Onyx SYTPT4227AB 42 in. LCD TV
Red light comes on when tv is turned on however it does not come on right away..maybe an hour later..just when ever.
  • 11,361 Answers
Tv plugged in and switched on, No standby light comes on there is a small red light on in the back of the set which would indicate power getting in but not switching on, Is there a fuse inside the unit or...
Tries tv unplug,replug it back like about an hour later for the tv to a resetting itself.Tv now,might and will work again sometimes.Not.Tries the power switch on the tv remote pushes off/on a few times,for the power supply board trying to kick start the tv Tuner signal board again.Still tv not have lit up the screen panel and work than it could be anythings in it boards are shorted or loses,if tv have a/c power to it.Take it to the tv shops for prices and quotes.Shops,must have trouble shoot and repair are ur best options.Replacement of refurbishes PCB boards,any replacements are a gest at best,if tv is a Plasma and still have power to the tv.
May 31, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
When i turn my tv on the red light goes to flashing green it comes on then immediatly it goes off but the light is on green... can you help
Tries tv unplug,replug it back about an hour later.The tv,now should reset itself back to factory setting.The tv should work now,not than the power supply board is dying,not giving the right voltage to the rest of the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | LG 42LG30 42 in. LCD HDTV
When press power on green light flashes and tv turns on but turns off right away
Try unplug,replug tv about an hour later.The tv now resetting,itself back to factory setting.The tv should work now.Not,than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Sep 09, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Cannot turn on TVour TV model is 60SBX78B, Hitachi project TV
If your remotes are out of the room and you try to turn and it still wont come as it should ,then You have a problem with the power switch or the supply, your unit needs to go to the shop . Sorry. DFD
Apr 11, 2009 | Televison & Video
Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Soyo Onyx SYTPT4227AB 42 in. LCD TV Logo
132 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
