Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 error on whirlpool duet washer - Whirlpool Duet GHW9150P Front Load Washer
  • 2,272 Answers
“F02” is a Long Drain error.If the drain time exceeds 8 minutes this error code will be displayed.In addition, a “SUDS” error may also be generated as a secondary error.This is an indication of a drain pump problem and/or clog in the drain line.You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
First thing to do here is take out the filter and clean out the grunge and gookus. If you find lots of stuff in there like pencils, nails, coins, etc., then it’s possible that these things have damaged the pump impeller. You can tell this visually by peering intently into the suction port of the pump with a flashlight. If any of the impeller vanes are broken off or if the impeller is jammed, then you need a new pump. First check out the drain filter:-- You will need to remove the bottom front panel by taking out 3 star head screws on the bottom of the panel near the floor and the panel will come right off. Then there is in the bottom center a white plastic cylindrical piece 2-3" in diameter with a screw cap, remove the cap and clean the filter. You may want to have some towels handy as the water gushed when I took mine off. Also, be sure to unplug the unit before doing this. 1. Use a shop vacuum to **** the water out of the drain hose. This reduces the water that runs out when you open the drain pump filter and it might remove a clog from the drain line.
2. Remove three torx screws to take of the toe panel on the front of the washer. If you have the machine on a pedestal, open or remove the drawer to get it out of the way.
3. Unscrew the cover on the drain filter. If you didn't follow step one have a towel ready. Remove the pennies, screws, ball point pens, etc from the filter. Look for clogs.
4. If the problem reoccurs you probably need to replace the pump. I ordered one from an appliance parts store on the internet for over $100. The current pump model # in 280187 at various part stores.
5. Remove the little screw just under the drain plug and unhook the unit from the bottom of the washer. This will allow you to turn the unit a bit to reach the clamps that hold the hoses in place.
6. Removing and replacing the hose clamps is the only hard part. It might help to have a small pair of vise grips - I used channel-lock pliers and they kept slipping. Putting a bright work light inside helped.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 10, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
    Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
    Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
    With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
    With the filter out clean and install it back into washer.
    Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
    If you require a new drain pump motor, you can purchase the part from the link below.
    - See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
    Sep 06, 2014 | Whirlpool Washing Machines
    F- code 02
    How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
    With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
    Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
    Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    What does F-02 flashing on the display of my Whirlpool Duet washer mean?
    Hello & Welcome to FixYa
    F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
    Kevin
    Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    My washer is displaying an "F02" message. What does this mean?
    If the drain time exceeds eight minutes, the water valves are turned off
    and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
    display.
    NOTE: After four minutes the “Sud” error will be displayed, then four
    minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
    Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
    Duet service manual and codes
    Rate it or hate it:
    Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F-02 error code on whirlpool front loader duet
    http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
    May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F/02 Long Drain
    If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
    NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Press PAUSE/CANCEL twice to clear the display.
    • Check the drain hose and make sure it is not plugged or kinked.
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects.
    • If the above does not correct the problem, replace the pump
    Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My washer show error(f-02
    F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
    Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I get the error code S02 on my Duet washer. It
    02 is a slow drain,
    yopu can check your pump
    take off the back wall and hoses,, have towels ready
    you will loose water,,
    inspect the inside of the pump and all hoses
    Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    162 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
