Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
How do i remove the grohe 28287 body spray. I am trying to clean mineral deposits from the parts. I can get the body spray head removed. But then there is the next white plastic piece that just appears to rotate. How do I remove that piece to get it off and cleaned?
2 Suggested Answers
SOURCE: I need to remove 2 Grohe 19 724 Pressure Balance
try rotating the faceplate in counter-clock wise fashion. this is a maybe.
Posted on Jul 23, 2010
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
We have a water softner AO Smith and we did the release valve on it and now it wont stop dripping.
Do you mean a water heater? Not sure why a RELIEF valve would be on a water softener.
Many times if a relief valve is not tested regularly it can gat minerals and deposits in it that can prevent it from sealing back up when tripped.
Sometimes tripping it quickly with the lever can make it work again. It is a realativly easy and inexpensive part to change.
Turn off water and relieve pressure on tank. Have the new one doped up and ready. Remove the old one and put the new one right in. Test the new one and you're done.
This valve should be tested monthly and a gallon or so of water drawn from the bottom of the heater as minerals and sedimet build up in the bottom. The water heater will last longer and be more effecient if seviced reguarly.
Jun 09, 2010 | Water Heaters
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
The water temp is set to the lowest thermostat setting; however, the water is extremely hot and often throws the safety breaker loaded on the heater itself...... I reset the red button and it heats.........
probably has lime and mineral deposits on thermostat and is not getting a correct reading turn off water supply and electrical - drain tank remove screws to heater elements and if build up try cleaning or if to bad replace same with the stat
Feb 15, 2010 | RELIANCE ELECTRIC WATER HEATER
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Remove the build up in a hot water tank
All you can do is to flush the water tank with the power off until you get clear water. The buildup is caused by hard water mineral deposits. You definitely need a water softener to prevent further accumulation. I found mine at sears on sale a few years ago, they were fairly reasonable and the installation wasn't that bad to do.
Jan 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water is not clear any more we have white residue in the kettle. We did change the filter and emptied the tank 3 times before insulting the new filters.
I don't believe that any filtration system is capable of removing dissolved calcium from water and that is what causes the white deposits. Water softeners will, but I don't like the idea of dissolved salts in our tap water.
Oct 24, 2009 | General Electric GE SmartWater Household...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Whenever i pull out the head on my grohe ladylux faucet, water starts to run back along the hose and down under the sink. i've replaced the head itself and the o ring but it still does it. can anyone help...
call grohe and have them send you the hole unit hose and all they warranty it it for life it is obvious there is a slite crack in the head base, they will send it for free
Apr 13, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
337 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
Craig Butler
Craig Butler
ray gallant
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
