Question about Optoma TX1080 Projector
I have an OPTOMA TX1080 Projector being controlled via RS232. When it sits for more than 20-30 minutes, it won't turn back on with an ON command or the remote. In order to get control of the projector again the plug must be unplugged and plugged back in. Once on, RS232 ON and OFF commands work normally. OFF, wait 60 seconds, goes to Standby mode. On turns it back on. This works unless the units sits for 20-30 minutes in Standby mode. Then we need to Unplug. Any Ideas?
Benimur
  • 6966 Answers
SOURCE: no signal optoma ep739
One good thing is that you are running XP. Will work on the premise (that you have posted) worked before and the driver (ForceWare91.31) was the only thing changed.
Let's try the easy ones first. Activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your projector. Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
or
do the same with nView Properties.
The hard ones are registry and/or inf editing, though I am reluctant to even suggest.
Incidentally, there is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
If all else fails, you may have to rollback/downgrade your driver.
Cheers.
Posted on Jan 20, 2008
SOURCE: Optoma H56 - turns off just after start up.
You have a blown bulb. I have the same projector and it had the same problem. The bulb is blown replace it and you should be fine.
If you are not sure of my solution you need to know that your projector will look like it is starting up and the bulb will partially light up but never come up to full brightness, then the projector will shut down. This will happen over and over until it just gets to the point it just turns on (the fan comes on and then about 30 - 60 seconds later the fan turns off.
Replace the bulb and you should be fine.
Been there done that!
Posted on Sep 25, 2008
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
SOURCE: optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
webkruzer1
  • 17 Answers
SOURCE: My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Posted on Apr 09, 2009
The screen turn green on my Optoma TX1080 DLP projector what is the problem
Usually, that means that there is an issue with the cable connecting the computer to the projector. Check to make sure none of the pins are bent or broken. Aslo see if a differnt cable works correctly.
Nov 18, 2014 | Optoma TX1080 Projector
Projector
What is the model number?
Nov 23, 2013 | Optoma Office Equipment & Supplies
What is pc contol
When using a special cable, pins 1, 4 and 7 of the PC control connector on the rear of the projector are used to receive RS232 serial commands from the PC to control various functions remotely in the projector.
Mar 02, 2011 | NEC VT460 Multimedia Projector
New bulb, fan working, after 10 mins of operation get posterized image; suspect overheating; dust has been cleaned out; has not been taken apart
Hi!
Is the projector placed in a box or an area where it could generate overheating? Is this projector still within warranty?
Please feel free to update me. Cheers!
Feb 04, 2011 | Optoma TX1080 Projector
RS 232 control
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
Dec 28, 2008 | Panasonic PT-AE2000U Projector
Dvd10 optoma projector makes a loud noise
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
May 07, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma TX1080 Projector Logo
153 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
