Question about Uniden Lands Phones
Dual line phone not recognizing line 2 - Uniden Lands Phones
  • 532 Answers
Check in the customer side of the NID. Ensure that the green and red pair of your cable is attached to the screw posts for Line 1. Confirm that the black and yellow wires are available but not connected to screw posts. If they have been clipped, see my advice about reworking your entrance cable. If you find that your black and yellow pair is in use, the green and red pair of your cable may be defective. In most cases, if your station cable has only a single pair or has a defective pair, I recommend obtaining professional assistance, unless you want to install new cable yourself to add the second line.
Step 2 - Determine how you want your jack connections wired. You may need to obtain new jacks or special adapter plugs. You have several options on how to connect your jacks:
Step 3 - Examine the routing of your phone cable to determine where all junctions exist. If you find junctions, ensure that all wires of the same color are connected together. You may find that the black and yellow wires were not previously connected at junctions. If you need to rewire junctions to connect the black and yellow wires, you may wish to use a junction block. Jacks may also be a junction location. I recommend using an ohm meter to perform a continuity check of the pair between each junction location and your wires at the NID.
Step 4 - Open your existing jacks and ensure that cable with two pairs is routed to each jack. You may find that a jack is used as a junction point, with multiple cables attached to the same jack. Rewire each jack according to the jack connection method you selected in Step 2.
Step 5 - Test your work. In the customer side of the NID, connect the black wire to the same screw post as the green wire and the yellow wire to the same screw post as the red wire. Use a known good phone and ensure that you can get dial tone and place a call at each jack for Line 1 and Line 2. Disconnect the black and yellow wires in the customer side of the NID.
Step 6 -Contact your phone company and order your second line.
Thanks.
Posted on Jul 10, 2010
I have two phone lines one for phone and one for fax is there any way i can connect my fax machine to the fax line only and not have to use an adapter
You can have the single out jack replaced with a dual outlet jack. To rewire it yourself, use the Blue/Blue White wires for Line 1 and use the Orange/Orange White wires for Line 2. If you older wiring then the colors are Green/Red for Line 1 and Yellow/Black for Line 2.
Jul 08, 2014 | RCA 25201RE1 Corded Phone
Bios reset
If BIOS doesn't recognize CD Rom or USB, I would try updating the BIOS first. It is available at the link below. You may want to update the other drivers as well.
Dell Precision System BIOS 2 6 0 Driver Details Dell US
Apr 06, 2014 | Dell Precision 390 Workstation Tower,...
I can change Line2 to line1 in my phone there in no out going n my mobile how to change line 2 to line 1
To change from lines between line 1 and line 2 follow the steps below,
Press menu > Settings > Calls or Line 1 or Line 2 for dual line
phones then press the Change key to change it.
Thank You
Aug 12, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I have 3 of the 954 model. If im using the phone
Do you have DSL on the first line? I would say that you have split the line to the phones so that they are not able to recognize the off hook from your office phone because each phone has a DSL filter. So take your phone line from the back of the DSL modem (line 1) and split it to all of the phones. Put the filter in the line, if you need one before the splitter.
Jun 15, 2010 | AT&T 954 Corded Phone
K599 phone not getting connect to PC. laptop suggested that the USB is not recongnized
Connect the phone to the computer by way of USB, when it state that the computer doesn't recognize it, re-start the computer with the phone connected. It should recognize it now.
Oct 29, 2009 | Dual Electronics CECT P168 Cellular Phone
I've i9+++ phone. It does not work with two sims inserted
It should just work - about the only thing I can think of is that there is an option under settings that controls the dual SIM mode, and that should be set to "Dual SIM open".
Jul 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Second SIM not working
Settings>Dual SIM settings>Select "Dual SIM open>click OK
Jun 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Only one sim works
there are two different lines for different sims....as LINE 1 AND LINE 2...there is an option for changing the line. then u can use both the sim. i hope this works. and if problem persists, u can contact the dealer. ur cell is under varranty period so dont worry. if the cell is faulty, u can claim to replace the set.
take care
Dec 16, 2008 | Microsoft Windows XP Professional With...
Lands Phones Logo
21 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
