Question about Whirlpool GGW9868K Gas Dryer
Kenmore 90 Plus Dryer is not heating up - Whirlpool GGW9868K Gas Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
Bgillespie
  • 89 Answers
SOURCE: Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Posted on Dec 17, 2007
  • 178 Answers
SOURCE: no heat for dryer
Need to look at replacing the thermostats and heating element whaich are accessible behind the dryer in a small panel. Be very careful to watch for sharp edges and disconnect the power before you do ANYTHING else. It's a relatively easy fix and you can get the parts feom www.marcone.com
Posted on Mar 14, 2008
Sea Breeze
  • 4654 Answers
SOURCE: how to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
Posted on Mar 21, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 90
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All Kenmore dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Aug 21, 2009
  • 2128 Answers
SOURCE: 9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Posted on Nov 07, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
I have a dryer kenmore 90 plus series 110.68972890 is electric ,and won't heat i need assistance ,thank oyu
heatman101
Mar 07, 2011 | Dryers
We turn on the dryer and it doesn't get any heat
Here is a video to walk you thru the troubleshooting process.
Jan 11, 2011 | Kenmore 73952 Gas Dryer
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Whirlpool GGW9868K Gas Dryer Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
