Question about HP PSC 2210 All-In-One InkJet Printer
I REPLACED MY INK CARTRIDGES. I WAS PROMPTED TO
I REPLACED MY INK CARTRIDGES. I WAS PROMPTED TO ALIGN THE CARTRIDGES. IT IS INDICATING THAT THE PAPER IS TOO NARROW. I AM USING 8.5X11 PAPER.
  • 2,272 Answers
Ignore the error and continue printing. The print job might still be acceptable even if the paper size and paper type settings are not an exact match.
  1. Press Enter on the control panel to clear the error message.
  2. Try the print job again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
    Use the HP product software, also known as the printer driver, to change the print settings for your paper size and type depending on your version of Microsoft Word.
    1. In Microsoft Word, click File , and then click Print .
    2. Make sure that your HP product is in the Name drop-down list box, and then clickProperties .
    3. Click the Features tab, or the Paper/Quality tab.
    4. Select a paper size from the Size drop-down list.If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
      1. Select Custom from the drop-down list.
      2. In the Custom Paper Size dialog box, type a name for the new custom size.
      3. In the Width and Height boxes, type the dimensions.
      4. Select the unit of measurement, and then click Save .
      5. Click OK to close the Custom Paper Size dialog box, and then click OKagain to close the Properties dialog box. NOTE: You must exit the Properties dialog box to apply your changes.
      6. Open the Properties dialog box again, and then select the new custom size from the Size drop-down list.
    5. Select the paper type.
      1. In the Paper Type or Type is drop-down list, click More .
      2. Click the desired paper type, and then click OK .
    6. Select the paper source from the Paper Source drop-down list.
    7. Change any other settings, and then click OK to close the Properties dialog box.
    8. Try the print job again.
      Paper mismatch errors occur because the printer scans the width of the paper before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper Mismatch' or 'Paper too Narrow ' error.The error message might also display when you load the correct paper, just reinstall the printer driver if above procedure does not helps. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 10, 2010
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Apr 19, 2011 | HP Office Equipment & Supplies
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Printer
This issue occurs if the alignment page is not perfectly or with good colors. Replace the low ink cartridge. If the ink levels are good do the following steps to clean cartridges :
1. Turn the unit on and open the lid or top cover.
2. Remove the cartridges.
3. Using a clean, dry lint-free cloth (a coffee filter works well),
wipe the cartridge contacts, from the top to the bottom. The contact
area of the cartridge should be rubbed briskly to remove the waxy
lubricant material from the gold contacts.
4. The contacts inside the printer may also require cleaning. Using a
clean, dry, lint-free cloth, 5. gently wipe the contacts, from the
top to the bottom.
5. Re-insert the cartridges and close the printer's top cover.
Steps to manually align cartridges
1. Press Setup until Maintenance appears, and then press Enter.
2. Press until Align Cartridge appears, and then press Enter. Two pages are printed, one with instructions and one with patterns.
3. Follow the instructions on the instruction page, then place the page with patterns on the glass and press Enter. The cartridges are aligned correctly.
If the issue persists do the below to by pass alignment :
Press Setup and Options (or Copy Options) simultaneously when align message is prompted on the All-in-One.
Thanks
Dec 22, 2007 | HP PSC 2110 Color Printer
HP PSC 2210 All-In-One InkJet Printer Logo
195 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
