Question about White Sewing Sewing Machines
Nothng happens when I step on the foot peddle
I have an old White sewing machine which sews beautifully. I was sewing, ran out of bobbin thread, wound thread onto the bobbin and put it in the case and went to begin sewing again and nothing happened when I stepped on the foot peddle - - it was completely silent. The light is on so i know it's getting electricity. Any suggestions?
  • 980 Answers
Check the pins on the machine plug to make sure none have been pushed in, check the cables for any breaks but make sure the plug is out of the wall first, if you can undo the plug on the lead to check it all well and good, failing that take the foot control and lead into a sewing machine shop so it can be tested
Posted on Jul 14, 2010
Bernina KL 117. How do I adjust the bobbin tention?
By "crow's nest" are your referring to bird nesting? What happens is the top thread creates a mess of thread under the fabric. It is a top thread issue, not bobbin.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension at the midway point and retest your machine. Adjust the top tension until the top and bobbin threads meet in the middle of the fabric.
If you need further assistance with tension, the following may help:
Understanding Thread Tension Threads
If the fabric is not feeding, then check the feed dogs. Are they moving backward, dropping, moving forward and then rising again? If not, then something is amiss with the feed dog mechanism. Check to make sure the feed dogs have not been dropped for darning. Another thing is make sure the stitch length is set high enough to actually advance fabric. There is also a presser foot pressure adjustment that, on your machine, is probably inside the top cover. There is a big screwhead directly above the presser foot. This can increase or decrease the pressure the presser foot applies to the fabric. Another possibility is that the feed dog teeth may be worn down with use.
Since yours is an older machine and possibly has not been used and oiled frequently, mechanisms may have seized over time.
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Feb 05, 2018 | Bernina Sewing Machines
Elna 6000 sewing machine, machine running very slowly and will not speed up when more pressure applied to foot peddle. More details below ?
This happened with my 50 year old Elna Supermatic. It ran a bit slow, so I oiled it and it ran again okay. But then it got slower, and I had to turn the wheel to get it to start and then it would run. But then even that didn't work. No go, period. I checked the foot pedal which had a bit of lint inside but no obvious problems. But the light worked so power was getting through to the machine.
I took it in for service, and the repair guy said that the brushes inside the electric motor (they supply power to the turning part called the armature) were worn out and no longer making contact. $11.00 for new ones, and a service/cleaning charge, and it's running at full power again.
Aug 20, 2017 | Elna Sewing Machines
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
The needle will not stay threaded every time i mash the peddle to start sewing, the needle comes unthreaded
Place the upper thread, along with your lower thread UNDER the presser foot....you may not be allowing enough thread off of the bobbin and roll. Pull out the thread to about 6 inches and see what happens, Happy Sewing!
Jul 23, 2011 | Singer 7436 - INGENUITY
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
BOBBIN THREAD
omyGod!! Thank you sooo much!!! I changed the tension on the top of the machine, like you said and now, it is working beautifully, God bless You!!!
sandylou
Dec 08, 2007 | Sewing Machines
Open Questions:
Sewing Machines Logo
98 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
