Question about Carrier Heating & Cooling
Heat comes on when the temperature setting calls for cool.
Can anyone point me in the right direction to solve this issue.
I have a Carrier AC/Heat pump with a totaline thermostat. Heat comes on when the temperature setting calls for cool.
The airhandler model is FY4ANF030, the compressor is 25HBA33OA003, and the Totaline thermostat is a P474-0100.
It was working fine and is about 4 years old.
Thanks
Ken
  • 74 Answers
Getting heat in the cooling mode leans toward the reversing valve in the outside unit. it changes the flow of refergerint so that the hot air you get outside in the summer is blown inside in the winter. another possibility is that the reversing valve isn't getting 24v check to see if you have 24v at O and C either at the t-stat, furnace, or the outside unit. if you check at the furnace rember the safty switch for the lower door if that switch is open you will have no power. i would look at the t stat first if you have 24v there go to the outside . 24v present outside will mean a bad valve or board, no 24v means a bad or broken conection in the control wire between the stat and the outside unit(usally the orange wire)
Posted on Jul 11, 2010
Need a quick fix for a Carrier that won't heat. Ac works, fan works, auto for heat doesn't.
Could be the capacitor or the heating element (or igniter if it's a gas unit). Unless you're a qualified HVAC repairman, call your local HVAC company to come take a look at it.
Dec 13, 2017 | Carrier Heating & Cooling
Totaline P274-1200 flashing all characters
check the conections try contact sprey
May 13, 2014 | Carrier Heating & Cooling
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
Totaline thermostat P274-0200 just stopped working...can't figure out why,
check condenser fan line. over heat condenser so have not cooling in home.no cooling so Thermostat not worked.if it's ok. check Thermostat volb lick .
May 28, 2012 | Carrier Totaline P291-1003 Capacitor 10mfd...
Need awireing digram for totaline thermostat P274-0200.
I am familiar with totaline products, give me more info, is it a heat pump system, a gas system, a dual fuel system? I just need more info to help you out. Mr. G
Aug 08, 2011 | Heating & Cooling
I need a wiring diagram for my carrier heat pump MOD 38YCC030300
call ur carrier supply house near u they will be able to help u unless they r too lazt to help but they have access to all that someplace like whittichen supply or totaline or weathertech
Feb 20, 2010 | Heating & Cooling
My totaline thermostat is blinking ''L6'' Furnace is operating ok, filter is clean. I can't figure out how to reset it and don't have a manuel.
Well..I just recently noticed this problem on mine and cant seem to find anyone to help me other than to call for furnace service..but the more i look into this ..the more i wonder if the code is L6 or Lb for low battery.
Jan 27, 2010 | Heating & Cooling
Where can I find a copy of the schematics for an older model carrier heat pump
Find your closest TOTALINE (Carrier parts dept) and see if they would be kind enough to give you a web link or print it out. You can try the carrier website, parts but I think one has to be registered with carrier to access that information.
May 06, 2009 | Heating & Cooling
No heat
Your compressor sounds like isn't working? And the problem is if we are lucky you just lost the capacitor. turn off the breaker to the ac/heat pump unit. Open the electrical panel on condenser locate the capacitor if it is swelled up like puffed up can then for sure it is bad. It has two sides to the capacitor one for the fan and one for the compressor. If you have a meter check it in ohms. If you don't have a meter take the capacitor to a heating and air conditioning parts house and get a new one just like the one you have very important to get right size. let me know how it turns out. ken
Dec 20, 2008 | Carrier 38BRC048 Air Conditioner
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
363 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
