Question about Armitron 0501643FA Wrist Watch
HOW TO CHANGE BATTERY
HOW TO GET INTO BATTERY COMPARTMENT
    Genius:
  • 1,970 Answers
Mcdevito75 here, Depending on your watch itself, Basically you"d remove the back cover, then release any hold down linkages on the battery, then replace the battery, hold down linkages and cover. The BEST BET is to look for a small watch repair shop in your area for this battery replacement as it may take special jewelers screwdrivers to change the battery.
Posted on Jul 10, 2010
Cartier Women's Tank Watch
What has been the issue when the repairs have been done? My experience with Tanks is that any reputable watch shop will replace the battery for $20. I don't know why it has cost you so much, but if the model you have is an auto-winder, then there is no way to retrofit a battery - although for $600 someone may be able to change the internal watch out completely.
Jan 31, 2014 | Cartier Tank Francaise W51001Q3 Wrist...
I have a Timex Wacky Wake-up Alarm clock and can't
When you are setting the alarm on the wacky wake-up timex alarm, if you keep pressing FWD, you will see a small PM in the bottom right hand corner. When the PM sign is gone, you will now that it is set to AM.
Mar 09, 2012 | Timex Watches
Waterford crystal watch. how do i set the time? i just replaced the battery and the clock is functioning but cannot figure how to set time.
There is a very tiny flap to the right of the battery compartment. You lift up on it and rotate it. As you do, the time will change. When you get the correct time, put the flap back to the down position.
Oct 15, 2011 | Guess WaterPro G12557L Watch for Women
Can you change the battery in the chest strap for polar f6
There are two types of straps for Polar:
1) hard rubber/ solid - These can not have the battery changed.
2) soft strap with connector in middle - these you can change the battery.
If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
Jan 12, 2011 | Polar F6 Wrist Watch
How do I change battery on my gametime watch? how do I remove back casing?
My GAMETIME watch has a back which just pops off. Once in the battery compartment, you will see plastic disk, with a molded frame. This just simply pulls off, and is not secured in place. You should not have to pry it.
Once this is removed, the battery is revealed. My model takes a SR626SW. To remove the cell, use something small to get under the exposed side. You should be able to pop the cell out without much force.
Before you replace the battery take this opportunity to clean the rim where the backing was. Carefully install the new cell, and replace the cover.
Sep 21, 2010 | Gametime Watches
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Need help replacing battery in my nike Imara Womens watch? Which way does battery go in with plastic cradle?
    1. Use a coin turn the battery hatch one-quarter turn counter-clockwise
    2. Remove old battery from compartment. Keep plastic cradle and replate with 395/SW927R battery. Replace the new battery positive side facing up in the plastic cradle into the metal compartment in the watch. Ensure all three little tabs line up and twist cradle to lock into place. Make sure the O-ring is in proper placement on the cover and replace the battery hatch ensuring it is sealed completely!
    Jan 28, 2010 | Nike Imara Run WR0075-014 Wrist Watch
    The Seiko s149 will not display anything on the screen.
    We had to change the internal battery on ours today. There are 4 screws on the back of the case and 3 inside the AA battery compartment. Careful pulling the front and back apart as there are some wires that attach between the two. Two of the three screws need to be removed to get the CR2430 battery out to replace it. We now have the watch screen...just need to remember how to operate it...need a new users manual.
    Sep 25, 2009 | Seiko 300 Lap Memory Stopwatch
    Battery Change on T-Touch
    there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
    Oct 28, 2007 | Tissot T-Touch T33759851
    Armitron 0501643FA Wrist Watch Logo
    663 people viewed this question
    Top Armitron Watches Experts
    Ansel Alberto
    Ansel Alberto
    Michael Vincent Cruz
    Are you an Armitron Watch Expert? Answer questions, earn points and help others
