Question about Premier Kitchen Ranges
Oven too hot and uneven heat
I have a premier 20" range EAK10M0P1
It is less than 2 years old. Recently, we are having troubles mantaining the oven temperature which gets way toooo hot. It doesn't seem to be regulating itself. I have made sure the vent hole is clear. I make sure not to turn to broil. I set it at 350 and it was at 500 when I turned it off. The on indicator light is also not working tho it works when I turn on the stove top burner.
  • 494 Answers
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
Posted on Jul 10, 2010
I have a Kenmore Elite Double Oven Range Model 790.9750. It's just 2 years old. It has been burning food only in the middle of the left side of the upper oven. Nothing cooks correctly because that
Check your door seal by doing a paper-pull test. If the paper pulls out easily on one side and not the other, then you found your problem. You might be able to "tweak" the door, but be careful - if you twist the door too much, you could break the glass. The other (and safer) solution is to replace the door seal. Another thing that could cause uneaven heating would be an element that has a "hot spot", but this is rare. Finally, if the insulation of the oven cavity was done improperly at the factory, that could also cuase uneven heating, but this is even rarer than an element with a hot spot. In all my 9 years of servicing ranges, I only encounter this cause 1 time. Ussually it's a damaged or compressed door seal.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 23, 2014 | Kenmore Kitchen Ranges
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Less than 5yrs. old...sensor replaced, oven does
check your element for a hi resistance or hot spot it will be pitted and discolored and its ready to break there,not enough current can pass through that spot to heat-up properly
Jul 10, 2009 | Whirlpool RS610 Electric Kitchen Range
I need to remove the oven element. the plate that holds it appears to be riveted in place not screwed, unless screws are just worn (17 year old premier chef coordinate series).
These are screws you see. They are oxidized and the slots in the head are probably gone. Best approach is to spray with Pam (or equivalent) cooking oil, then use vise grips to remove the screws.
May 27, 2009 | Premiere Ranges EAK220 Electric Kitchen...
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Ranges Logo
202 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
