Question about Whirlpool LER5636P Electric Dryer
In the whirlpool large capicity, 2 cycle washer, model lA5500xswo, serial #la55oos the washer over fills, so we have to stand there untill it fills to the point that we think its full and then we have to advance it to the next cycle for it to adjitate?
  • 348 Answers
There is a small plastic hose on the inside of the tub that connects to a sensor. At times these sensor hoses get clogged with detergent or become dissconnected with the sensor. Either way the sensor isn't getting the signal that the tub is filled. You will have to gain access to the inside and check this out. Last resort call Sears and they should walk you through. Good luck.
Posted on Jul 11, 2010
Whirlpool model wtw6600sw2 makes a squeeling noise when attempting to fill
I would call the Whirlpool machine repair person for a quote as only an experienced engineer will know what the problem is eric
Jan 13, 2018 | Whirlpool Cabrio WTW6600SBT Top Load...
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Does the Model #WTW7340XW2 Whirlpool clothes washer delay cycle fill with water before the delay cycle begins. Can I use this cycle as a soak cycle? Thank you, Shiela Walker
Hello, After looking at your service book no it should not fill untill it starts the cycle. Sorry...If this helps please rate me. Thank You :)
Jun 09, 2011 | Whirlpool Washing Machines
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
Nov 23, 2010 | Whirlpool Washing Machines
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
The machine fills up with water but does not shutoff.
The water level is controlled by a pressure switch that is located behind the load level selector knob in the operator console. The pressure switch has electrical connections and an air hose that runs to the bottom of the wash tub. In many cases the air hose comes loose from the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
Read through the link and let me know if you have any questions. If this isn't a simple matter of a loose air hose, verify your electrical contacts are clean. If all these preliminary checks fail, replace your pressure switch. I hope this helps you.
Jun 29, 2009 | Whirlpool ET8CHEXSQ Dryer
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water won't stay in washer ...
either the pump is broken or the drainhose is lose or too low.
There is also in this machine something called a drain protector. This might be faulty too and i think that would be the cheapest to see about that first
LINK for the water drain including all parts
LINK for all machine parts motor and pump
May 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LER5636P Electric Dryer Logo
142 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
