Hi, My Flymo lawnmower has become very noisy and increased vibration. Blade and belt has been changed, all screws tighten and nothing is broken but its very noisy. It wasn't like that before. I also cant find any repair centre in manchester, so, don't know what to do. I would appreciate if you could help. Thank you M.Tariq
  • 487 Answers
Give me the model number of this mower please.
Posted on Apr 19, 2008
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
What is causing Scotsman icemaker to moan
perhaps it's unhappy? I can't say i blame it, if I had to sit there all day in the freezing cold making ice I would moan too.
here's a list of possible problems
If it makes excessive noise:-
Problem and Likely Causes/ Probable Solutions
Fan blade vibrates Blade is bent Replace fan blade
Fan motor mount is broken Replace motor mount
Compressor vibrates Mounting loose Check mounting
Water pump vibrates Pump bearings worn Replace pump
Panels vibrate Mounting screws loose Tighten screws
and ice can groan as it expands, but that only applies to large icebergs
May 14, 2014 | Scotsman Freezers
Flymo tines
What are you referring to as tines, it sounds like you are working on a roto-tiller. I will need more info as well. Model# Unit type-ie. lawnmower. Are talking about the blades? If so the there is a large nut that bolts the blade to the lawnmower. Remove bolt by holding blade with gloved hand and long breaker bar. You can strike the breaker bar with a three pound hand sledge to break it loose. Replace or sharpen blade as necessary. Apply grease or never-seize ti threads on crankshaft, spin on the bolt and tighten with long breaker bar. Good luck!!!!! If this is a tiller, then let us know, ok?
Mar 26, 2014 | Garden
How to fit belt on flymo tc380
Too replace the belt you need to remove the motor and base plate assembly, remove the box, remove the front cover over the motor, pull the two wires off the motor terminals, turn the mower upside down,remove the blade bolt and blade, remove the impellor, remove the four cross head screws underneath, there are two more screws toward the front of the machine, once all out the motor and base plate will come out as an assenbly, slacken the four motor screws and push the motor forward, remove the old belt and fit the new one, wedge a screw driver between the motor housing and base plate force the motot forward to tention the belt at the same time re tighten the motor screws, re assemble in the reverse order.
Jun 16, 2012 | Garden
How do I lower my lawnmower blade (flymow)
Good day. Unfortunately there are no settings to lower the blade on a Flymo. Hope this helps
May 10, 2011 | Beckett Water Gardening Water Garden...
Hai I'm Prem here that my lc nuovo go sound around fan coolend area like very noisy and vibration thx
With the engine cold, check the fan blade assembly for cracks. Some blade assemblies have a large ring or band around the outside of the blade tips. If it is broken the fan becomes off-balance while spinning and will vibrate badly. Fan replacement will likely need to be done to cure this problem.
Jan 06, 2011 | Yamaha V-Max Motorcycles
The blades on my Flymo 350 lawnmower have become blunt. How easy it is to replace them once i have purchased replacement blades?
It is a matter of unscrewing the bolt that holds the blade on just make sure when installing the new blade that it locks into the mounting shaft correctly on some mowers there is a mating hole to shaft pattern that allows the blade to interlock onto the shaft yours may just have a rectangular support the blade fits into just make sure when you tighten the blade it is set into the shaft correctly and you are wearing a pair of raw hide gloves when holding the blade as you tighten or somehow block the blade with a piece of two by four wood.
Sep 11, 2009 | Garden
My Flymo microlite 28 lawnmower is very noisy...
You got it, replace the disc before you use it again.
Jul 09, 2009 | Garden
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
Washing Machines Logo
456 people viewed this question
Top Washing Machines Experts
