Question about Kenmore 57029 Side by Side Refrigerator
I have a Kenmore Coldspot m# 57282791. Last night, it stopped staying cold, and I have not heard the motor/compressor come on at all since then (the part that cools the fridge, right?) There is a small fan back near the water line hookup that is working, but it is very quiet for hours now. The fridge side is almost lukewarm, and the freezer side has mushy peas in it. It is older, built in 1998 and we bought it used. It has worked well for the last year with no problems except occasionally freezing some produce.
  • 10,515 Answers
If the compressor is not running, it could be either a bad relay or compressor.This is not an issue with defrost components or temp. control .If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
Testimonial: "If I knew anything about the fridge, I can tell this info would have been very important."
I have a Kenmore Coldspot side by side refrigerator m#57282791 made 6/98. About 2 yrs ago the ice despenser started puting black flakes in cup with ice so I quit using dispenser and getting it from inside. Then about a yr ago the water dispenser stopped working. Now it quit making ice period. It sounds like it is but no ice. HELP!
Posted on Nov 20, 2010
    Genius:
  • 1,417 Answers
what this indicate is that there is power disconnection on the fridge, the fridge it self is ok/alright .
what you will need to check on from here is the fuse on the wire connected to the main power supply replace it with a better one but if there is any ,but if not the then check on the wire connected to the capacitor if there is any form of disconnection onthe capacitor then the problem is solve .
thank and thanks for using fixya.
  • 1 more comment
  • Mary Finney Jul 10, 2010
    I am not mechanically inclined at all. I don't know what a capacitor is/what it looks like. Can you advise? Also, there is still power going to the unit since the fan is working, the light inside works too.
  • Oloyede Monsuru Jul 10, 2010
    hello,
    what i will advice you to do from here since you are not technically inclined
    is the get you self a technician (invite a technician to visit the fridge) to give
    you an helping hand
    but on the other question, there is still a power supply connected to the fan
    and the light unit
    thank you. once again .
  • Oloyede Monsuru Jul 11, 2010
    hello,
    how can i help you now different from the solution provided to the problem posted to me ?.
    thank you .
Compressor replaced recently after housing had burned. Currently the 10658582890 kenmore coldspot is not staying consistenly cool (fridge) or keeping the freezer cold.
You should check the warranty they gave with repair thecompressor could be defective or they didn't braze the joints well and refrigerant leaked out
Apr 06, 2016 | Kenmore Refrigerators
Kenmore coldspot not working properly after power outage
I am glad you made it thru the storm OK. I am in New Orleans and I am no stranger to what you guys went thru.
First, are you sure the compressor is running?
Post back to me.
Nov 02, 2012 | Refrigerators
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
Jun 07, 2012 | Kenmore Refrigerators
Kenmore Coldspot refrigerator Model #57282791 no water from dispenser
When was the last time you changed the fridge water filter. Sounds like its blocked if no water is coming out of the hose at the bottom front. Also depending on the fridge design two other culprits are possible.the electric switch that is pressed that cativates the water valve to open and let water pass and the second the water valve itself. I would lean toward the water valve at the back of the fridge, as you said it was getting worse over time u til it just stopped.
Oct 02, 2017 | Kenmore Refrigerators
Kenmore Coldspot refrigerator not staying cold. Model 106 9710582.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 14, 2011 | Kenmore Refrigerators
Kenmore Coldspot not keeping cold. Ice in freezer
What are your temp controls set to? If the controls are set to the max setting and it won't reach temp, you could have a broad range of problems ranging from bad door gaskets, to bad temp controls, to a low refrigerant charge, to possible a failing mechanical part such as a fan motor or compressor.
Jan 08, 2010 | Refrigerators
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore coldspot model #106.53594300 will not cool
Check the condenser. Cheap remedy. Have it replaced.
Jul 12, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
567 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
