Question about Intel D945GCCR Motherboard
Car won't start when hot. only starts in morning when cool. is this the icm?
    President:
  • 2,571 Answers
Sounds like the CPU HSF is loose or has stopped
The HSF.. heat sink and fan needs to be running or the motherboard sensors will just shut the computer down.
This board in an intel LGA775 and uses this type of CPU cooler
http://www.aria.co.uk/Products/Components/Fans%2C+Heatsinks%2C+Coolers/CPU+Coolers/?x=12&p_order=price_asc&p=cF9zdHlsZT1kZXRhaWwmcF9wcm9kdWN0c1BlclBhZ2U9Jg==
You can get a new 1 for under £10 and they are not to hard to fit
Posted on Jul 10, 2010
Once the truck is hot, and i turn it off It will not start up util I allow it to cool down.
A couple of things maybe: the ignition control module, or the crank position sensor. I f you have a distributor, the ICM would be inside the dist. If a coil pack, the ICM is probably underneath the coils on the coil pack.
Sometimes, an ignition coil too will get hot and short out. That's 3 things you could check. Have you tried to check for spark when it won't start? If no spark, any of the 3 things noted. If you do have spark, see if the fuel pump is quitting and putting out no pressure.
Mar 16, 2016 | Cars & Trucks
My 91 accord has been giving me grief 4 months. Sure would appreciate any help - TX GREASEMONKEY, u have been on the mark b4, want to take a shot... Its my only transportation and has been down 4 a month....
When you say you have fuel, do you have normal fuel pressure at the injectors ? Because Honda cars are known for faulty fuel pump relays.
The relay stops powering the pump when it gets hot but will start back up when the relay cools off.
Jul 25, 2014 | Cars & Trucks
Car dies when motor is hot
There is a good chance your ICM has gone bad and will need to be replaced. you can remove it and have it tested before you buy the new ICM at most parts store.
When the ICM starts to go bad, the engine will start to have issues to what you described. Good luck and keep us posted.
molson02536
Jan 14, 2014 | 1996 Chevrolet Camaro
Bad cam shaft senser
You could have a faulty engine coolant sensor or intake air temperature sensor. Fuel injectors clogged or dirty flooding engine.
Clean fuel injectors, replace fuel filter and air filter, and see if the problem persists.
If it does ECT sensor is bad. If CMP sensor was bad, the vehicle won\'t start whether cold or hot. CKP senso and CMP sensor work together if either one fails, the vehicle won\'t start. Have the vehicle code scanned.
Apr 18, 2013 | 1999 Chevrolet Tracker
Car wont start when hot
there's a host of things that would do that, one is your starter Bendix could be getting hot, when it cools your able to start again, but as I've said many things can do that , maybe a ignition module his breaking down when it gets hot. Mike j
Dec 07, 2012 | Cars & Trucks
I have a 97 blazer starts fine stalls at 230deg starts when cool
Check the electronics in the distributor. Chevs are notorious for the electronics going bad inside of the distributor.
Jun 01, 2010 | 1996 Chevrolet Blazer
My 3.8 olds 88 just just stops like turning the key off. you let is sit for half hour and it will restart. Is thire a maginet on the cam in side the timing chain cover?
Start with the simple and replace the fuel filter and inspect the ICM. (ignition control module) A failing ICM will stop working when it get's hot and when it cools off, it will work again and eventually the ICM will stop working at all.
Thank you for using fixya and start with the fuel filter if it has not been replaced once a year or 25,000 miles.
Apr 03, 2010 | 1999 Oldsmobile 88
OK I have a 97 savana 1500 van runs great until it gets hot and then when you shut it off and try to restart will not start acts ike no gas. pump runs, I thought maybe vapor lock but no go there either. It...
If you have good fuel pressure, then i'ld lean towards the Ignition Control Module (ICM) it's around $40.00 at Auto Zone. They work when there still cold and when they heat up, they start to fail till they cool down again and eventually they fail totally. Auto Zone will have the step by step instruction to getting the job done. The ICM is under the rotor in the distributor, and the wires may also be corroded or broken. Inspect for any damages to the wire harness in the distributor before installing the new ICM. Good luck and hope this helps.
Jun 25, 2009 | 1989 GMC K1500
Computer switches off when to hot and then won't start till cool
possibly control module, they like to fail when they get hot, if you can find it (in or by the distributor) and take it off, some auto parts stores can test them
Jan 16, 2009 | 1998 Hyundai Elantra
Intel D945GCCR Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
