Question about Danby DKC645BLS Compact Beverage Cooler
I took the inside panel off my Danby and found the black (tape, rubber, whatever it is that is on the copper wires had melted. What does this mean? Thanks, Jag
  • Jamie Garis Jul 11, 2010
    Anyone else have an answer, about either question? thanks
  • 532 Answers
If the black tape and rubber melted on the copper wire, it means the copper wire is damage.
you will have to replace the copper wire on panel of your Danby.
Thanks for contacting Fixya.
Posted on Jul 11, 2010
  • 6,993 Answers
it means that the things that got melted was as a result of heat or excess power supply entering into the unit. This is what must have caused the melting.
You need to replace those melted items.
Take care.
Posted on Jul 10, 2010
  • Jamie Garis Jul 10, 2010
    What would cause excess heat or power to enter - and what was the black stuff that melted on the wires? thx
Why is the cooling coil in the freezer compartment icing up all the time regardless of amount kept in freezer or time of year?
Increase the temperature, ensure the door closes correctly against the seals, make sure the thermostat is working correctly ...
Mar 01, 2017 | Refrigerators
Temp display is flashing "ee" but seems to be cold inside.
EE mean that the cable between the mainboard and the display have a problem. I think it doesn't affect the coldness of the unit.
There are an explanation manual behind the back bottom panel.
In my case soon after having reset this error, the cable melted and took in fire.
How to check:
There is a black panel under the two drawer with 2 screws (left/right). The board is behind, the cable which melted in my case was a grey one connected to a black one.
Aug 28, 2013 | Haier Dd400rs Refrigerator
How to wire a toggle switch for non working horn
My suggestion ask that mechanic to do it for you on the side maybe and see how much he would charge if you don't know anything much about going under the hood that would be best, if not here goes. First find the horn make sure you can get to it there should be a connector or plug on it should being the key word. Find it and remove it, you will need a wire long enough to run from the horn around and through some place in the firewall next to the wall between the engine and inside and back out to the battery so make sure its long enough to do that as well make sure the wire is 2 different colors inside sometimes they come copper on one side and silver color on the other or you can find black and red coated wires an 18 gauge speaker wire should work 15 to 20 ft should be plenty tape the ends of the wires with 8 inches excess hanging to the battery one end and the other to the horn not connected just so it holds the wire while you run it to inside the car string the wire around under the hood so its not all over the engine but around it and not on anything that gets hot to melt it. Make sure you know when you run it inside which side of the bend (you will have to bend it to get it inside the cab) make sure you know which side was going to the battery and which to the horn when you have the wire inside the car cut the wire on the copper side or the red side but dont cut the black shave back the plastic on the cut wire so you can get to the bare wire on the toggle switch any kind with 2 connectors on it is ok or you can also get a push button kind so it works like the horn find the positive connector on it and negative connector, connect the side of the red/copper wire that is going to the battery to the positive side if it has no positive or neg it doesn't matter either side then. Now connect the other side of the spliced wire to the negative or other side of the switch. once this is done under the hood look for positive and negative on the horn strip wire ends so you can get to bare wire connect the red/copper to the pos. and black/silver to the neg. You can use connectors for this or you can twist the wires around the connectors like a twist tie and tape with black electrical tape not clear tape. then on the battery put the red to pos. and black to neg. I would splice off enough plastic coating to wrap wire around battery terminal connector not the post make sure you connect the pos. last and don't touch the neg wire to anything else. then test the horn if it is working unhook the pos. side of the wire on the battery until you get ready for inspection and when done remove this so you don't have battery drain or other problems. Good luck
Nov 29, 2011 | Pontiac Sunfire Cars & Trucks
My power windows in driver side and passenger back window wont go up or down.
A master switch may be at falt, but try you may want to check power gets to window motors, remove door panels and use your test lite activate switch and see if lites Ok then needs a window motor if no your master switch is bad..
Very rarely on this year you may also found broken wires between drivers door and vehicle, where harness pass from door to inside car, disconet harnes from inside left kick panel and pull it out towars door pull black rubber boot back remove electrical tape and check all wires if any open or split repair and rechek al over. good luck
Dec 05, 2010 | 1996 Toyota Camry
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
I have a 1989 Toyota Camry and am having difficulty with driver seat belt activation. What sensor or component tells the seatbelt to activate? Where is it located?
I have a 1990 camry and my driver side belt stopped working too. The problem is the wires that run from the door to inside the vehicle. Open your door, look in the doorjam for the black rubber piece. The wires inside it bend every time you open and close your door and eventually break. The only solution is to cut the rubber and resplice the wires which is a big pain in the ***. It took me a few frustrating hours, but, I heard it's easier if you take the door off. I left a lengthy amount of wire, wrapped in electrical tape, behind the front quarter panel to prevent it from bending again. This is a very common problem with camrys of these years.
Feb 22, 2009 | 1991 Toyota Camry
LG Dishwasher LE error
When you repair the wires, be sure to wrap the wire harness is plastic like the type you would find in Safeway produce section.  This will keep the wire harness from getting melted on to the black insulation and creating this problem again.
Jul 12, 2008 | LG LDF6810 Built-in Dishwasher
2004 audi a4 cabrio radio problem
The aerial is in the boot lid. A wire runs down through a thick corrugated tube. Many bends over time fatigue and break the wire. I simply found the break and repaired the wire , coax wire, repositioned the wire fine! Audi do a replacement around £100 that goes all th way to the radio!
NB handle in boot lining has a hidden screw that must be removed to pop off lining.
Jun 14, 2008 | 2003 Audi A4 Cabriolet
Power windows, door locks and mirrors inop.
Sounds familiar - I pulled the rubber boot back and found the black wire was broken. I stripped the wires and put on a couple bullet connectors (terminators) and all is good. Just wish I would have seen this post before I took the door panel off... Oh well...
May 21, 2008 | 2004 Jeep Grand Cherokee
It won't register a tape entering
check all wire connections again inside, especially the motor to eject the tape.
Jul 18, 2007 | Sony SLV-778HF VHS VCR
Danby DKC645BLS Compact Beverage Cooler Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
