Question about HP Pavilion a1410n (ER890AA) PC Desktop
My speakers on the monitor isnt working
How can I fix my speakers?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 53 Answers
Make sure your speakers are plugged in, turned on, and properly connected to the computer. You've probably checked this, but it's amazing how little problems like this (or the computer's sound being muted) manage to confound people.
Plug the speakers in to another computer, if possible. If the speakers work with the other computer, proceed to the next step. If they don't, you've probably got a problem within the speakers themselves.
Check your sound drivers:
  • Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the "Hardware" tab and then the "Device Manager" button.
  • Expand the "Sounds, video, and game controllers" heading to find your sound card. The name will depend on what sound card is installed on your PC. It will most likely have a name containing "audio." It should look something similar to the example above. You'll know immediately if there is a major driver error because an exclamation point (!) will show over the card's icon.
  • Double-click on the name of the sound card to open a new window. In the new properties window click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's onscreen instructions to update your driver. You can also contact the manufacturer of your PC for the most recent audio drivers. They can usually be found online.
  • If you already have the most recent driver, click the "Uninstall Driver" button. Then restart your computer. When you restart your computer, the driver should reinstall automatically. If it does not, install it manually with software (or a download) from the manufacturer.
  • Check the sound card itself. Properly shut down your PC and then disconnect all cables on the back of your PC, including the power cable. Open up the CPU, making sure to touch a grounded metal object (a doorknob or metal desk will work, for example) before opening up the case. This will discharge any static electricity you have built up, which could damage your computer
  • Locate the audio plug on the back of your PC. The sound card should be in the corresponding location on the inside of the PC. Remove the sound card and put it back in the microsoft website has detailed directions for installing a sound card; to remove one, simply do the reverse. Once you have the sound card back in, reattach the cables you unplugged earlier and boot your PC.
    • If your sound card is built into the motherboard do not try to remove it. Your entire mother board will be needed to be replaced if the sound card is the problem. Another option is to buy a separate PCI sound card and then install it. Ads by Google
      '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
      ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '9206048113+7733764704+1640266093+5860073694+9911500640+5009222491+3607312525+8962074949+8941458308+6876289738+7122150828' + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = "250x250_as"; //-->
    • If you're having problems with speakers emitting a static or crackling noise, it may be caused by a high speed internet box. Moving the box away from the speakers or the speakers away from the box may help if this is the case.
    • In some cases, you will be receiving high amounts of static from the "CD Player" and / or "Line in" channels. This can be corrected simply by lowering the volume or muting these channels in Volume control (Start>All programs>Accessories>Entertainment>Volume control)
    Posted on Jul 10, 2010
    No sound
    Does the monitor have its own speakers? Some do not come with speakers. If there are speakers, then maybe an adjustment through buttons on the monitor is required. Or maybe the A/V to the monitor from the PC is not getting to the monitor.
    Feb 23, 2014 | Gateway Computers & Internet
    One speaker isnt working
    You should return them to the place you bought them from. You might need your recepit. Otherwise visit the Skull Candy website. DO NOT attempt to repair them otherwise your warranty will be void.
    Jul 10, 2010 | Skull Candy G.I. Consumer Headphones
    JBL Speakers won't play
    Check all your connections. it might be that the green audio jack isnt put into the rear of your pc properly.
    Jan 02, 2010 | Audio Players & Recorders
    Bose Companion 2 Speakers won't work with Sony Vio Laptop
    You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
    If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
    Oct 30, 2009 | Sony Audio Players & Recorders
    No connection
    First, hopefully you are looking for an output on your monitor, not an input. But if there is no jack for the speakers to plug into on the monitor, then there should be a connection on the back of the computer for the speakers. Look for the (( ))-> symbol for the speaker output.
    Aug 18, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
    Speaker sound isnt clear for emachines speakers
    DOWNLOAD NEW AUDIO DRIVER FOR YOUR CPU AND IT SHOULD FIX IT
    May 14, 2009 | Audio Players & Recorders
    Earjack
    Yeah, I had the same problem. There isnt really a fix, but when you unplug the jack, make sure the speakers work, by turning on speakerphone (The little speaker symbol will appear) or try calling someone. If it isnt working just wiggle the jack in the port a little bit and try plugging and unplugging it. I just think the port gets stuck or something so it thinks that the jack is still in there when it isnt, thus leading to the speakers not working. This is a really annoying problem. Pretty poor design, but an easy enough fix I suppose.
    Apr 18, 2009 | LG VOYAGER VX10000 Cellular Phone
    No sound on new LG Flatiron Monitor
    You need to get a set of powered computer speakers!
    I always found that stand alone speakers are much better than the ones in the monitor.
    Jerry G.
    Apr 30, 2008 | LG Flatron L1919S LCD Monitor
    Audio Problems
    see if the drivers are loaded correctlly, uninstall the audio device and scan for hardware change, see if installs properlly next time
    Mar 19, 2008 | HP Combo Case HP PAVILION Speakers, Mouse,...
    Only one comes on
    sounds like one of the channels on your amp is playing up.take it to an audio specilist to have this checked. if your rear right speaker isnt working this wouldnt cause the sub to stop working
    Mar 14, 2007 | Lanzar MAX12D Car Subwoofer
    HP Pavilion a1410n (ER890AA) PC Desktop Logo
    150 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
